Power Steering in 90 Minutes!
/ Power Steering in 90 Minutes! #81
Just noticed this old post (#19) when rereading the whole thread.
That is the same system that was used on some Ford cars in the 50's & 60's the valve was built in. If you could find one in the junk yard might be able to adpt to tractor.
The ford valves on many of the 60-late 70's models seem to be one of the best ( common and cheapest) examples I have found so far.
I think the kit R.Davis sold was simply one of these automotive valves mounted on a steering cylinder. Maybe that was already obvious to some.....I can be a little slow :eek:
/ Power Steering in 90 Minutes! #82
Is this Rick Davis out of business? said web page was unavailable.
/ Power Steering in 90 Minutes! #83
Last I heard his brother had taken over. If the phone number and address in the prior page get you no where then I would assume the business is gone.
/ Power Steering in 90 Minutes! #84
Today 50's ~ 60's Ford components might be the best alternative to add power steering on any tractor.
Long ago I had a Willys Wagon that an owner of a body shop had modified in his spare time. 292 Ford V8, and the air conditioning and power steering also transferred over from a late 50's Ford. The steering components were a simple bolt-on similar to the Yanmar PS kits. This worked well.
/ Power Steering in 90 Minutes! #85
It is a shame that the guy that sold the actuator and cylinder assembly on the original post stopped selling them. I am putting a new sector shaft and and ball nut and shaft in my L185 kutbota and power steering is next on the list.
/ Power Steering in 90 Minutes! #88
Seems like it might be easier to get an electric power steering unit out of a junked car than to try to gin up a hydraulic one, particularly if you have a small pump. https://www.youtube.com/watch?v=BuShsA_cqNk.
That's a good point. I'm not real happy with the power steering (Yanmar-USA option) on my YM186D. Digging into a gravel pile etc with the loader, its natural to go into the pile until the engine starts to bog down - and at low rpm I can't raise or roll back the bucket to ease up on how big a bite I'm taking. I think the diverter to the PS is stealing hydraulic force. My larger YM240 (manual steering) has the identical hydraulic pump and a 5 ft bucket, compared to the 4 ft on the little tractor, and its hydraulics work about the same at any reasonable rpm.
Think of how a Caterpillar operator eases up on the bite he's taking, raises the blade, as the tractor slows down. I lose that ability to ease up, as I lose rpm. Not ideal for a little tractor that is set up primarily for landscaping, moving dirt around.
I love the little YM186D but I think this dealer add-on PS kit isn't up to the top quality of the rest of the tractor. Also - Yanmar parts remain available for this early-80's tractor, but the American PS kit supplier is long gone and there are no service parts for it. A Ford-based kit could be maintained nearly forever. I may eventually have to replace the kit with a manual-steering drag link.
/ Power Steering in 90 Minutes! #89
I have mine plumbed in series after the loader. I do lose power steering when I'm using the loader but not too big a deal. My plan is to mount a belt driven pump from a small foreign car with a remote reservoir so it's independent. Others have done something similar here at TBN. That may be a workaround for the diverter valve issue.
/ Power Steering in 90 Minutes! #90
Look at a Volvo 240, 260, 740, 760, 780 or 940. They all had remote reservoirs on some years.
Aaron Z
/ Power Steering in 90 Minutes! #91
All the Hondas I've owned have them, the pump is nice and small so should fit into small spaces. Finding a V-belt one would be ideal but I assume the pulley can be swapped.
/ Power Steering in 90 Minutes! #92
That's why I suggested the Volvo ones, they are pretty much the same size, use a v-belt pulley and have a remote remote reservoir.
Aaron Z
/ Power Steering in 90 Minutes! #94
Actually most all the Volvo units (pumps) are Saginaw and are much the same as the General Motors units.
The differences are pretty much rotation (serpentine vs. V-belt) and relief valve pressure and pump volume. They make around 1400 psi.
Good luck, Fred
/ Power Steering in 90 Minutes! #97
I bought a kit for a Ford and adapted it to my Kubota L285, now my 3 point don't work. Any ideas?
/ Power Steering in 90 Minutes! #99
Would need to see how it's plumbed. Hydraulic fluid takes the path of least restriction.
iDrive TDS-2010H...
2024 CATERPILLAR 255 SKID STEER (A52709)
2024 CATERPILLAR...
2025 Ford Transit Cargo Van (A56858)
2025 Ford Transit...
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
UNUSED SDLANCH SDLGC100 ELECTRIC GOLFCART (A60430)
UNUSED SDLANCH...
