Fire pit
/ Fire pit #1
Backwoods Welding
Have been requested so here it is! I get the pit in two halves called hemispheres. I weld one half to a base then weld the other one to it. I project the design I want on the ball and trace it. Then I fire up the plasma cutter! Sorry the app won't let me post more than one pic at a time so bear with me.
/ Fire pit
Welded together
/ Fire pit
Cutting the 175# ball!
/ Fire pit
Finished product!
/ Fire pit
Test burn
/ Fire pit
Other side
/ Fire pit #8
That's pretty cool!!!!
/ Fire pit #9
Where do you get the steel balls, hemishperes ?
/ Fire pit
There are several metal forming companies out there, I get mine from a place called Commercial Metal Forming in Youngstown, Ohio
/ Fire pit
It's sad but I finished that pit right in the middle of the big wildfires out in California this summer and a few of my friends named this pit the Californian because the cabin and trees are on fire and of course the bears
/ Fire pit #16
Really like it! Want to make one myself... Bout how much do the spheres run? Did u draw the stencil yourself?
You must have a steady hand with that plasma!
Great job!
/ Fire pit
The material is $350 to get and we lay out the design on computer and project it on the sphere. We then trace it with a paint marker and cut.
/ Fire pit #19
If you had a design that wasn't open enough to put wood in on the top could you make the two hemispheres hinged? I saw a picture once in a welding magazine from a place in China that made hemispheres and balls. They made everything from tiny little ones about 1/2" in diameter all the way up past 72". They made them out of steel, stainless, and brass with your choice of finishes. The only reason I remember it was that they took a picture of their warehouse full of "balls". 1000s of them every size you could imagine. I wonder if it would be worth pricing them from China if you do enough of them.
