Old JD hyd coupling
/ Old JD hyd coupling #1
LukeD
Marksville, LA
'69 John Deere 3020
I'be got a JD 1020 that I use as my rake tractor. I just bought a 10 wheel rake and got rid of the side delivery rake. But my hyd remote is the old JD style. My rake (and my other tractors) have ISO. So I'm looking for just a conversion to plug into the JD to convert, without rebuilding it. Thoughts on this? I see that they list this one on Amazon, but it says old international style. Is that the same as ISO? Any recommendations?
Apache 39041625 John Deere Cone Old to International Harvester Old Male Hydraulic Quick Disconnect Coupler (S25-4-5): Amazon.com: Industrial & Scientific
/ Old JD hyd coupling #2
Yes that will work . Actually it is Pioneer to JD , same thing . I think there should be an o-ring on the female end also .
/ Old JD hyd coupling #3
The IHC won't work. You need this one in photo from TSC Old style JD to ISO.
Well I'm gonna have to see if they have it in stock at TSC. Thats cheaper than the ones I found online
/ Old JD hyd coupling #5
Did I miss something or did I say Pioneer to JD cone ?
/ Old JD hyd coupling #6
Kevin
No offense intended but if I'm reading the spec's correct and I fairly confident I am the Safeway S25-4-1 is the correct fitting to accept the ISO male tip BUT the S25-4-5 is made to accept the larger male IHC tip similar to the male end on S25-4-4. That's how I remember them when I sold them in JD parts dept.
Jim
/ Old JD hyd coupling #8
No problem I just didn't want OP buying wrong adapter.
They had the international ones in stock at TSC, and I could tell that it was not the right one. But like always, they only had 1 in stock of the correct one. So I got them to order me 2 of them. But it will take 2-3 weeks to come in
/ Old JD hyd coupling #10
Yepper and they make them forwards and backwards as I had to have male JDs with female ISOs and and Male ISOs with female JDs depending on the tractor and implement. $35 sticks in my mind, don't remember if that's a pair or each.
Jack Daniels Sign (A64557)
Jack Daniels Sign...
2020 Freightliner CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 Freightliner...
2015 Ford Taurus AWD Sedan (A64557)
2015 Ford Taurus...
JOHN DEERE 1770NT - 12R30" VACUUM PLANTER (A64278)
JOHN DEERE 1770NT...
2013 Ford Explorer 4x4 SUV (A64557)
2013 Ford Explorer...
2020 Chevrolet Tahoe SUV (A64557)
2020 Chevrolet...
