Buying Advice Bobcat Toolcat- Is it the right tractor for my Facility
   / Bobcat Toolcat- Is it the right tractor for my Facility
I have 2 baseball fields plus smaller areas in front of buildings
I have two 100 car parking lots
in the last 3 years I spent over $100,000 on contracted snow removal and landscaping. I want to do it in house with the correct equipment but don't want to over do it.
   / Bobcat Toolcat- Is it the right tractor for my Facility #12
A tractor with a mid mount PTO would run a front end snow thrower and a belly mower. Zero turn is fine, but a cabbed tractor has AC. ;)
   / Bobcat Toolcat- Is it the right tractor for my Facility #14
How much is the budget for all of this?
A new toolcat is 50K plus. You can buy some really sweet stuff for 50K.
50 grand is ALMOST enough to buy a Grand L 3560 with loader, mower and snow blower in Canada, LOL
   / Bobcat Toolcat- Is it the right tractor for my Facility #15
I would get two separate machines. Spend $10,000 on a good front mount mower. You can plow the small stuff with that. A UTV or CUT will both work for the parking lots and trash duties. Take your pick.
   / Bobcat Toolcat- Is it the right tractor for my Facility #16
Mowing that much, I would get a Kubota F3990 (or a similar Toro).
They are available with a cab and AC and will knock the socks off of a tractor for mowing.
Aaron Z
   / Bobcat Toolcat- Is it the right tractor for my Facility #17
I've never understood the application for a Toolcat. Its an expensive comprise. You could buy a zero turn mower, UTV, and small tractor for about the same price.
Very expensive. I looked into it for a short time and thought about selling my S185 skid steer. I decided to stay where I am. And you're right. I got a fairly low hour skid steer, 73 inch snowblower, forks, grapple bucket and a Ferris zero turn for far, far less than a new Toolcat with zero attachments.
In my area, even rusted out, high hour Toolcats were going well over $20k.
   / Bobcat Toolcat- Is it the right tractor for my Facility #18
If your dollar was worth more than 3 pesos, you wouldn't have that problem. :p OP is in the US. :D
   / Bobcat Toolcat- Is it the right tractor for my Facility #19
A Toolcat will do all the things you mentioned. They are very popular with commercial snow removers.
The Toolcat costs more because it is commercial quality not home owner quality. You are getting an air tight cab, front and rear independent suspension, four wheel steering, four wheel drive, crab steer and a passenger seat that you can't get on the other machines mentioned.
For mowing get the 5610 model, no overheating issues with grass and dust clogging the radiator screen..
No problem hauling a trash trailer, just don't try this at home! :D
The trailer is 1,000 pounds heavier than the 4,000 pound tow rating. :shocked:
   / Bobcat Toolcat- Is it the right tractor for my Facility #20
Believe it or not, that was priced when our dollar was almost equal. We get gouged on everything up here.
2014 Dodge Avenger Sedan (A56859)
2014 Dodge Avenger...
72" ROCK BUCKET (A52706)
72" ROCK BUCKET...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
2016 John Deere 5055E 4WD Utility Tractor (A55973)
2016 John Deere...
TANK MANIFOLD (A55745)
