welding project: log catcher
/ welding project: log catcher #1
s219
Super Member
Virginia USA
Kubota L3200, Deere X380, Kubota RTV-X
Made this up for my splitter a couple weeks ago and finally got around to posting pics. They wanted $80 for the factory catcher, and I knew I could weld a better one up for a fraction of that cost.
It's interesting to weld up a design with a lot of angled cuts and parts that need to match, as it really forces you to plan things and jig things properly.
/ welding project: log catcher #2
Good job. Looks like it will protect the engine too. BTW, looks like we have the same welding table. :D
/ welding project: log catcher #3
Looks very functional. :thumbsup:
I would skin my knuckles up pull starting with that on there. :confused2:
It's a good thing the pull aims out sideways, because I didn't even think about that part! That would be just like me to overlook something important though...
/ welding project: log catcher #6
Great weldment. ... You will need a couple braces angled back to the beam to ease the cantelever stress at the root, or sizable log splits flopping down will finally crack it.
/ welding project: log catcher #7
Is it welded to the beam or bolted?
Do have enough access to the motor and pump?
/ welding project: log catcher #8
Looks like a "Dirty Hands" log splitter and I did the same thing (log catcher) with some scrap metal, we both saved $$$. BTW, I love my splitter it hasn't met a log it couldn't split. I wedged a 2x10 from the "I" beam frame up to the log bracket at an angle to support larger logs.
Bolted. Was tempted to weld it in place, but would have to deal with the gas tank first to make welding safe, and the splitter already had bolt holes. Plenty of access to everything below.
I may do that at some point -- or use a block of wood as mentioned above -- but so far the rigidity of the catcher and mount is more than enough for the wood I am handling. I have put a healthy amount of body weight on the catcher to test it.
2012 Jeep Compass 4WD SUV (A59231)
2012 Jeep Compass...
2011 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR3BJ325816 (A61165)
2011 International...
12ft 9in Altec Service Bed (A61165)
12ft 9in Altec...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
2015 Nissan Altima Sedan (A59231)
2015 Nissan Altima...
John Deere 12in Channel Tooth Bucket Excavator Attachment (A60352)
John Deere 12in...
