Comparison lawn tractor or atv mower for mixed, rough terrain
   / lawn tractor or atv mower for mixed, rough terrain #1
bluelou
New York
n/a
Site: I'm new to the world of outdoor power equipment and I just bought a place with 2 ac of very hilly and uneven grass plus 28 ac of mountainous woods with old logging trails.
Goal: Keep grass relatively short, maintain trails, medium-duty gardening.
Equipment: I'm not sure if a heavier duty lawn tractor like a Simplicity Legacy XL or Cub Cadet XT3 is an appropriate solution. Or, if I should consider an ATV/UTV with a pull mower. I'm undecided on the need for a PTO for attachments. Checklist likely includes 4WD, a strong frame, and lower center of gravity.
Mostly, I think I want something that will keep the grass shorter (doesn't have to look perfect), can pull a bucket, handle mowing rough, uneven hills, and ride very hilly trails for maintenance purposes. Other attachments like a front-end loader would be nice to have but aren't on the shopping list for this year. Maybe this is too much to ask for in a single piece of equipment. I'd appreciate any guidance.
Thx in advance,
Lou
P.S. Budget w/o PTO is +/- $6k-7k, With PTO +/- $10k-11k
   / lawn tractor or atv mower for mixed, rough terrain #2
I think you need a real tractor. 30 HP, 4x4, with a loader for starters.
   / lawn tractor or atv mower for mixed, rough terrain #3
Those lawn mowers will definitely not cut it on rough terrain -- poor ground clearance, poor tires, light construction. I wouldn't go any smaller than something sized like a Kubota B series. Even a BX is probably not enough.
Thank you, both, for your replies. I know this is a tractor site and not an ATV site but based on your replies I'm wondering now if an ATV/UTV isn't the better way to go. I can get a new Yamaha Kodiak 4WD ATV for $6300 + tow-behind trail mower for +/- $2k and be way under the $14-15k or so I'm seeing for the Kubota B 2301. If anyone would like to tell me why the ATV solution is the wrong or right way to go in this case I'd appreciate it.
   / lawn tractor or atv mower for mixed, rough terrain #5
Pretty sure you will need both ! I have a bush hog but do most of my mowing with the Kubota zero turn, holds the hills and mows through most anything . Don't have a rough cut mower for the RTV but wouldn't want to be without it for everything else.
   / lawn tractor or atv mower for mixed, rough terrain #6
For $11k you can find a good used compact utility tractor 25-30hp, with 4x4 and loader, and probably with a brush hog. You then have something that you can do just about ANYTHING with. If you spend $8300 on a new ATV and mower, you can only mow, and scoot up trails.
I tractor has a million uses, and will save you so much back pain it's not even funny. With that kind of acreage you're going to need one anyway.
Chris
   / lawn tractor or atv mower for mixed, rough terrain #7
You really, really need a tractor for 30 acres of woods and grass to manage. Your asking a lot out of an atv however given your budget, sounds like you have no choice. Welcome to TBN!
Citydude,
It appears I wasn't clear in what I'm looking to accomplish. I'm just rough cut mowing 2 acres and maintaining existing trails on the other 28 ac. Not cutting new trails, not doing much else other than light-duty gardening.
Maybe I end up doing what groundcover mentioned previously and buy both. So, the ATV would become a toy and I'd buy a tractor. But, for now, I just don't want to spend the $15k. At least, I'm not there yet...
   / lawn tractor or atv mower for mixed, rough terrain #9
You'll be throwing your money away on a Garden Tractor and/or ATV. I bought my Yanmar 276D (27 engine hp), 4x4, loader for 6K. It's been basically bulletproof for 7 & 1/2 years.
   / lawn tractor or atv mower for mixed, rough terrain #10
I got my 27hp 4x4 Ford 1715 with FEL and 5' brush hog for $8k. Low hours, and in amazing shape. I couldn't imagine life without it, and I only have three acres.
Chris
MISC TIRES (A54757)
MISC TIRES (A54757)
2019 Freightliner Day Cab (A55973)
2019 Freightliner...
2019 Dodge Charger Sedan (A56859)
2019 Dodge Charger...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
3-Tier Mesh Shelf With Wheels (A54816)
3-Tier Mesh Shelf...
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
