Buying Advice Info on mahindra 2538
   / Info on mahindra 2538 #31
I am comparing the 1538 HST and the 2538 HST. I currently have a 3316 HST. Primary use for the tractor will be cleaning out 4 40x400 poultry houses. Lifting slats, shaking litter from them and hauling them out, and pushing and piling 12-18 inch deep poultry litter and shavings. Dealer is pushing the TYM made 2538 to the tune of about $5000 less. He does not have the 1538 on the lot to do a side by side comparison. Since you've been shown the benefits of each tractor I'll ask...operating in such a small space would there be any benefit to the 1538? Why they price difference in the machines? What does the 1538 do better?
If you look at the specs side by side you'll find the machines to be very similarly capable in my opinion. (Links to spec sheets at bottom.) The main difference that you have already pointed out is that the 1538 HST is a Mitsubishi based machine and the 2538 HST is a TYM based product. Everything flows from there. I picked up from the guys that the 2538 is slightly more basic in terms of features, but fully capable for what I needed, and in fact I preferred the beefier front end and tires on the 2538 for the loader work I do. Having the mCRD engine in both caused it to be essentially a choice to save money and get a slightly more basic fit and finish. The 2538 is still a very nice product and excels in some areas over the 1538 in my opinion.
Any dealers or other owners on here please augment or correct my notes. Pictures side by side would be cool too if anyone has them. These are both fine machines.
Some notes:
Clutch - The 1538 HST has a manual clutch that you depress to start engine and engage the manual PTO lever, etc... The 2538 does not have that. My prior machine was a Max 25 which was essentially a smaller version of the 1538. I thought I would miss the manual clutch for engaging the PTO, or for quickly releasing cutter engagement in heavy stuff. In reality, the electrically actuated PTO on the 2538 works great too and having a manual and automatic switch gives you some flexibility that the 1538 does not have. I did like feathering on the PTO with my Max's clutch setup, but throttling down the 2538 still allows for a relatively smooth engagement. (I did opt for a Medium Duty 6' cutter which has a slip clutch, so that might help too...)
Loader control on the 1538 is by your right knee, whereas the 2538 is a traditional reach out front design. Some like the lower right set up, but I often stand up to get on material I am grappling and the front lever is better for me. Also, the bucket visibility in a tiny bit better on the 1538 than on my machine, but no biggie.
Front tires are a bit larger on the 2538. For all the loader work I have, I wanted the wider R4s. (This item was a big factor for me. Maybe silly and certainly not the most important thing, but I am glad the 2538 has beefy front tires.)
The 1538 front steering hydraulics are better shielded than the 2538 which has cylinders in front of the axle. This helps with turning radius, but if you were in heavy rough woods with skinny stumps in your way you may want to weld on some skid protectors there.
Turning radius is tighter on the 2538. It almost feels as good as my little Max 25. The specs show 2538 at 7.87 ft vs 9.2 ft for the 1538. (May help in your situation where space is tight.) Please check the overall lengths with loader though to make sure they are similar. Also, the brakes on the 2538 are on the left, so you can use true independent skid steering while running the hydro pedal. On the 1538 and also my Max the brakes are on the right which require you to be in cruise mode in order to make those super tight turns by slowing or stopping one of the rear tires while turning.
The 1538 uses a heel toe rocker HST pedal and the 2538 has forward/reverse pedals next to one another. Lots of controversy on that topic as to which is better, but I find both are very workable setups.
The 2538 fuel fill location is at the rear while the 1538 is in front of steering wheel. I prefer the rear location for easier access.
The 1538 has a suspension seat and cruise whereas the 2538 did not have either. I remedied that by swapping a suspension seat from a 2540 and also adding a cruise control upgrade for a total of +/- $500 negotiated during purchase.
The 2538 with loader is about 155 pounds heavier than the 1538 with loader so that is close to a wash. (2538 = 4,110# 1538 = 3,955#)
Both machines have quick detach loaders, but the 1538 stores the support leg inside the front loader cross rail, whereas the 2538 legs just fold back along the loader arms. Not quite as smooth looking, but did not bother me. Also the hydraulic lines on the 1538 run inside the loader arm for a bit whereas the 2538 has hard lines along the inside of the right frame. (Another minor detail, but worth pointing out.)
At the end of the day I would say the 1538 had a few nicer finishing touches. Perhaps a bit more "refined" in places, but I am quite pleased with the TYM/Mahindra workmanship of the 2538 and it is very close to what I was used to with the Mitsubishi based Max that I had. Also - the benefits I have noted above pushed me towards the less expensive machine that met more of my needs. I think you'll be pleased with either one and hope that the comments above help out. I really encourage you to try and get both of them side by side so you can touch, feel and put them through their paces.
Here are the spec sheets showing them to be almost identical on paper:
2538 http://mahindrausa.com/sites/default/files/tractor/pdf/23105 MAH5417 25Ser_8pg 010716_5.pdf
1538 http://mahindrausa.com/sites/default/files/tractor/pdf/23101 MAH5415 1500 Ser Bro 010716_0.pdf
Good luck!
   / Info on mahindra 2538 #32
All good points^ you must have had Gene runnin in circles :thumbsup:
The tires were a big plus to me and the price on the 2538.. I just really like the view from the seat (much better sight to the loader/ground) and leaver positions on the 1538 the engine is a bit more responsive to but I do like shuttle much better than HST so that would make my decision.. and save a bit of gap in the money. You gota really want/need it for 3k difference in a 38hp compact though.
   / Info on mahindra 2538 #33
Gotta make him earn his commission right? :) In actuality - Gene did a great job and when he became tired of my non stop questions, he just suggested I call and head down to corporate to wear those folks out for a while. I could have stayed there for hours. Although not a retail location there were new Mahindras as far as the eye could see.
   / Info on mahindra 2538 #34
2538 in action - grubbing roots and piling limbs
Compress and prep to mulch/cut
Cut and cleaned up - holes back raked - only brought the machine off idle to get the cutter up to 540 RPM
   / Info on mahindra 2538 #35
:thumbsup:
   / Info on mahindra 2538 #36
Gene's a great guy. He stayed late on a Saturday evening to answer all my questions before I signed the papers.
   / Info on mahindra 2538 #37
Just wanted to say hello, and let all of you know that the info in this thread really helped me make a decision on my new Mahindra 2538 TLB purchase. I was on the fence between the 1526 / 1538 / 2538.... I felt like the 2538, was the best bang for the buck with the features, and I liked the specs on the loader / backhoe a lot. I signed papers today, and I'll post up some pics when I get them. Dealer had to order the BH for it, so gotta wait a week to get it.
Looking forward to putting it to work.
   / Info on mahindra 2538 #39
Hi, I visited J5 yesterday and was looking at this very same model. I have a relative working at JD that questioned the quality of the mahindra product and was wondering if you are having any problems with the product or dealer? The price is much lower and I like the tractor. I would like to discuss your experience as this is my first tractor and am expecting to do similar work with it. Please let me know if we could meet somewhere like a Denny's around Willis and discuss. Lunch would be on me.
   / Info on mahindra 2538 #40
Welcome to TBN HappyTrails! :welcome:
Lots of great people on this site who are very helpful. I relied on advice found here back in 2012 when making my first purchase which as very useful. Did not contribute much for a few years, and then came back for more advice for our recent purchase. It was very helpful again. Now I'm trying to contribute a little bit and help others too.
With all due respect to your relative who works for JD, unless he worked for Mahindra or owned a Mahindra, it might be tough for him to question the quality of the product... I have had no problems that were not created by me, myself, and I. Is your relative up at the JD shop on North loop 336? I have bought a few Zero turns from those guys for a landscaper we use who has not established credit.
We have four years with a Mahindra Max 25, (sub manufactured by Mitsubishi), and now 3 short months with this 2538 HST, (TYM chassis/Mahindra engine), with no problems yet although I acknowledge it is still new. Mahindra makes/markets/sells a lot more tractors than JD these days on the international stage, and some of the wear and tear that that I've seen from the 3rd world countries gives me courage that I probably can't be as hard as those farmers on the machinery. BUT - there have been a few Mahindra owners with the odd leak here or there, and if you scour the forums you'll find a few major problems that have crept up with a couple series. In those cases having a good dealer makes a world of difference. With J5 having operations in Navasota, Conroe, and Normangee, they seem to be fairly well established and I have had a good relationship with the Conroe team. I have also seem some big problems with JDs, Kubotas, Kioti's, etc... But I still think they are fine tractors if chosen based on needs, capabilities and value.
I'd be happy to meet for a coffee or lunch sometime. Just send me a private message or email through TBN with your contact info and which J5 you visited, and I'll give you a ring. The J5 shop that I frequent is in Conroe and I am centrally located to The Woodlands, Tomball, Conroe and Willis areas.
Also - today is an important day. Remember the Alamo!
AUCTION STARTS HERE @ 9AM (A60429)
AUCTION STARTS...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
20' 1 Trip Shipping Container (A59814)
20' 1 Trip...
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
2013 VOLVO EC250DL EXCAVATOR (A60429)
2013 VOLVO EC250DL...
