3-Point Hitch ford 2120 3pt lift lever broke off
/ ford 2120 3pt lift lever broke off #1
firebirdcrzy
Callao, VA
Ford 2120
been a long time lurker of the sight and usually find the answers I am looking for. I hope someone can help me and I am attaching a parts diagram. My problem now is the shaft (#7) the the 3pt lift lever (#14) mounts to has broke off where it make the L shaped bend. After looking over the parts diagram (attached) it looks as if the lift cover has to be removed to replace the shaft (#7) Has anyone removed the lift cover from a 2120 that may give me some pointers?
  • scan.pdf
/ ford 2120 3pt lift lever broke off #2
I took this all apart a few years back on my 1920. No real advice, but it wasn't too hard. I guess the only think I can think of is to be careful of not ripping the gasket on the lift cylinder cover (flange w/ the lowering speed knob).
Here are some photos that may be helpful. Feel free to PM me if you have any questions.
/ ford 2120 3pt lift lever broke off #3
I would remove the shifter assembly, remove #7 by driving the pin out, wire brush the edges that broke off and clean up the joint well and weld it or have someone weld it. A bit of Ford blue spray paint and it'll be as good as new.
JC,
/ ford 2120 3pt lift lever broke off #4
Here are the photos I messed up posted.
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
2018 FREIGHTLINER CASCADIA SLEEPER (A59905)
2018 FREIGHTLINER...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
2013 Keystone Laredo LA329RE13 37ft. T/A Fifth Wheel Travel Trailer (A59231)
2013 Keystone...
