Reminiscing about older vehicles
   / Reminiscing about older vehicles #21
Had a 1977 MGB... don't want to go back there. Boot full of tools to go anywhere and get back home. There is a reason Brits drink warm beer. Lucas electrical!
mark
   / Reminiscing about older vehicles #22
Several in the Model A club have driven their cars around the world... others from tip of Alaska to the tip of South America...
They had everything they needed with them... might or might not work for a modern car.
In Syria, one of the cars broke a rear axle in a monster pothole that looked like a little water puddle...
Replaced the axle right on the side of the road with a few simple hand tools... they did have a spare.
Fuel was always questionable... a single bolt to separate the lower half of the carburetor and everything exposed for cleaning...
One of my friends had a light go out while traveling... pulled into a part store and they could not help... turns out the "Assembly" is a $1200 dealer only part...
Same thing happened to Mom's Toyota and $7 and no tools needed... good as new... changed it in a parking lot after going out to dinner.
   / Reminiscing about older vehicles #23
Yeah, I miss having to fill the battery, replace heater and radiator hoses, replace belts, pack wheel bearings, set the points, check the timing, fix the radiator, adjust the carb, fix the choke, replace the fuel pump.................all the time.............NOT.
   / Reminiscing about older vehicles #24
There's no doubt I'd like to have a 60's muscle car...as a toy. As a daily driver? Not so much.
My tune changed completely after one experience. Don't remember the specific year/date, but my vehicles were a 1984 Dodge Aries K, a 1967 Chevy K20 and a 1988 Dodge Dakota.
It was bitter cold and I went out at oh-dark-30 to go to work. No garage at the time.
I learned how to start vehicles in cold weather in Michigan in the 60's, so I'm not a beginner.
The K-car (Carburetted 4 cylinder) would NOT start. Barely turn over, not the first hint of fire.
The K20 had a new engine with a brand new Edelbrock carb and intake and a new battery. Same deal. Turn over slowly like the crank was stirring half-set tar, not a snowball's chance it was going to fire.
Hopped in the Dakota. 3.9V6, throttle body injection, electronic ignition. Turned the key and VROOOM! Took right off, and kept running without having to sit in a freezing cab diddling the throttle and choke praying it would keep running long enough to warm up. Flipped the heater on full blast and went back in the house.
Lost all interest in carburetted vehicles (and vehicles with points) right then and there.
   / Reminiscing about older vehicles #25
Still love the old cars but don't want to own one.Replace the points/plugs maybe 10,000 miles,drum brakes,maybe 15,000 miles out of a set of tires,10mpg out of a V8 and in our area rusted out in 6 years.
   / Reminiscing about older vehicles #26
I only own two vehicles that does not have carburetor... 1991 and 2002
1976 and newer is required to pass enhanced emission testing in California... it has become a real chore to smog the 1976 Triumph or BMW... the smog techs are really clueless when it comes to carburetors and two carbs on a car is a crisis...
When I bought my 1985 Van it was to be smog exempt 25 years later and then the legislature made it 30 years and now it is 1976 and newer...
So a 1976 car can be about $180 for tags and test if everything goes perfect.
   / Reminiscing about older vehicles #27
After all the problems I have had with electrical issues on cars and trucks since 2003 I miss my 63 Impala, 68 Firebird, 78 C10, 95 Bonneville.
I think my next car will be pre-computer and will get it restored like new.
   / Reminiscing about older vehicles #28
My 2nd car was a 72 Nova rag top. 20 years ago I was told that it was worth big $$$$ in restoreable condition. Wish I had it now. I remember buying a 79 Chevy PU new for exactly $7000. It was a Scotsdale with bucket seats, console automatic, ac. the works. Now it would cost what a small house would then. I do wonder if we are really better off or just think we are. Ed
I haven't priced one but my preferred truck is a Plain Jane F150 6cyl, 2x, 4sp. If it runs under 35,000 I would be surprised. I didn't pay that much for my house back in 1976
Harry K
   / Reminiscing about older vehicles #29
mark
Ah, the Prince if Darkness!
   / Reminiscing about older vehicles #30
Harry K
You might need to special order and I'm not clear as to available 4spd
One on my coworkers paid 33k for a V8 4WD and Auto... XL which is the base trim for most of us... had to go to farm country to find it...
John Deere 9450 Combine (A50514)
John Deere 9450...
12in Backhoe Bucket (A52128)
12in Backhoe...
Friesen 110 Seed Tender (A50515)
Friesen 110 Seed...
Land Honor Quick Attach Articulating Boom Brush Cutter (A50514)
Land Honor Quick...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A50046)
2018 FREIGHTLINER...
2016 Freightliner Cascadia Tandem Axle Road Tractor (A47384)
2016 Freightliner...
