So you think converting a Pin-On to QA is Easy!
   / So you think converting a Pin-On to QA is Easy! #61
Just the ease and availability of buying or possibly even renting is much better.
   / So you think converting a Pin-On to QA is Easy! #62
I'm thinking about converting the loader on my Kubota B2620 to SSQA. I have the LA364 loader. I thought I would cut the ears out of my bucket and reuse them with Titan's Quick Attach weld on brackets here: Tractor Pin-On Loader to Skid Steer Quick Attach Adapter tach kubota bobcat QT-K
Then weld a QA plate to the bucket. The plate would fill in the hole in the bucket and be welded there as well. I saw this documented in this thread http://www.tractorbynet.com/forums/attachments/270316-quick-attach-conversion-kit-need-6.html on post #54. The poster only posted once so I thought I would see if anyone else has done this, or has opinions one way or the other.
Thanks.
P.S. Great job K0ua. I'm thinking this might be a bit easier and cheaper.
Thanks.
Let us know. How it turns out. Pix too:)
   / So you think converting a Pin-On to QA is Easy! #65
Add on to old dead thread. Got info from Bobcat today. The ssqa hooks up to 70 different attachments from Bobcat.
   / So you think converting a Pin-On to QA is Easy! #66
I just did a Titan weld on conversion for an old IH 2250
Loaded. I looked for info on the conversion but didn't find much actual info on the fitment. The weld on plate was a nice piece but after welding the brackets on securely I found I had done it a bit low. Looking closer at the pics of others I find the bottom pin latch is close to level with the main pivot pin of the loader. The Titan plate extends 6" Lower and I welded the brackets on flush to the bottom ("didn't want it sticking down!"). Not sure why it hangs down so far.- more steel and weight that doesn't seem to have a purpose... I think it will be tolerable but I wish I had seen it before the welding.
   / So you think converting a Pin-On to QA is Easy! #68
I have been reading through the two current threads about reworking attachments for QA .Both are great jobs with a lot of perseverance .
I would have a little different approach I guess .My choice would be to leave the bucket completely in tact and build a face plate on the arms that had two heavy hooks that would lift the bucket by the top pins then using a diverter valve in the tilt line I would have two short stroke cylinders to push the bottom pins in after the bucket was lifted and rolled back to ensure it was locking .Then any further attachment I built would be made to hook to that faceplate . Just my vision based on some other equipment I have used or been around.
   / So you think converting a Pin-On to QA is Easy! #69
I did this conversion to my loader bucket a few years ago and had the same issues as the original poster. I seem to recall it taking me the better part of a day to do it. Tools used were oxy/acetylene torch set, Lincoln power mig 255 and an angle grinder utilizing 7" cutoff wheels. I do not own a plasma cutter. Glad it is done now, but was WAY more involved than I was planning on it being.
   / So you think converting a Pin-On to QA is Easy! #70
The disadvantage of your idea is, every attachment that you want to use would have to be modified. If you needed to rent one, it would not fit.
I bought my first SSQA attachment on craigslist before I had a machine to put it on, but I knew it would fit on whatever I bought, because SSQA dimensions are standardized.
And a lot of guys have added powered latches, like the Bobcat powered Bob-Tach to their QA.
UNUSED IRMC HIGH END ELECTRIC MASSAGE CHAIR (A57193)
UNUSED IRMC HIGH...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
2012 Chevrolet Traverse LTZ SUV (A53424)
2012 Chevrolet...
UNUSED FUTURE MINI EXCAVATOR RIPPER (A57193)
UNUSED FUTURE MINI...
2015 ATLAS COPCO XAS185 CD7 (A52707)
2015 ATLAS COPCO...
2017 FORD F-450 XL BUCKET TRUCK (A57192)
2017 FORD F-450 XL...
