Massey GC - Anyone build plows for FEL?
   / Massey GC - Anyone build plows for FEL? #1
LevesqueOnline
Saint John, New Brunswick
2022 Kioti CK2610SE
Hey all, im just wondering if people have built their own plows for the massey bucket and any experiences? I have seen some quick attach items like this Canada Forks - Universal Receiver which would be interesting but wondering what most people do.
I have a 60" plow from an ATV I was thinking I would have modified.
   / Massey GC - Anyone build plows for FEL? #2
very bad idea, don't ask how I know.
really, don't ask. :2cents:
   / Massey GC - Anyone build plows for FEL? #3
Well of course when you put it that way.... you know we have to ask : ) Tell on!
I was planning to do something similiar with my GC. I know many do it and I also know you kind of need to do it right. I was planning on putting about a 4 inch strip Rubber horse stall matt on the bottom edge of the blade. I also know you need to actually have trip springs etc. I can't see any reason not to do it if you do it right.
   / Massey GC - Anyone build plows for FEL? #4
I think the major deal is if you put the plow on the FEL, it tends to lift the front wheels and take away your steering ability.
I have been contemplating making a frame mount for my plow, pushing from the tractor's frame, and just using the FEL to lift and lower it.
There are some threads on here with similar builds.
Good luck,
Thomas
   / Massey GC - Anyone build plows for FEL? #5
I started developing an idea for a fel mounted plow this last summer but got way-laid by two other project efforts that I got completed . . . so likely a summer 2016 focus for the next item :)
   / Massey GC - Anyone build plows for FEL? #6
I built a 72" GC FEL plow, it works very well.
There are so many advantages to having it mounted on the loader, I would never have a frame mounted plow again.
This photo is v1.0. I have made some slight modifications since then.
I plow 325' of gravel drive. I do not use, or need chains.
The casters keep the plow above the gravel.
The plow floats on hinges, where it attaches to the loader frame.
There is also slop where it pivots. That allows it to rotate some, to follow the terrain.
Springs are also necessary to allow it to fold flat, if you hit something.
   / Massey GC - Anyone build plows for FEL? #7
Ok I for one would like to hear the advantages of a loader mount over a frame mount. I have a frame mount but I am always open to new ideas. Ed
Thats pretty awesome looking, also our loaders have freefloat so they actually flow with the ground level.
Ray do you have more pics showing how it was built?
   / Massey GC - Anyone build plows for FEL? #9
That looks like a pretty simple design thanks for sharing. It seems high off of the ground even assuming your using the loader controls to pivot the blade forward. Does the blade have the ability to contact the ground?
That blade looks real similar to the one I have and am thinking of using. How deep of snow have you handled with that setup?
Here is my blade.
   / Massey GC - Anyone build plows for FEL? #10
Yes, I can use the bucket dump cylinders to tilt the plow, so that the cutting edge contacts the ground.
Normally, I keep it about 2" above that point.
There is a piece of 1.5" steel pipe with tabs welded on it, bolted on the cutting edge so it doesn't dig.
Using the loader in float, results in the arms contacting the ground. It worked out better to have the arms stationary, and let the plow float.
I quickly learned with v1.0, which had a rigid plow, and did not float, that I needed that, and the ability rotate some to follow the ground. The rotation was accomplished by having slop in the bolt that the plow pivots from side to side on. It doesn't take much slop, to give it the ability to move a couple of inches up, or down, on the outer edge.
The current v2.0 has the frame that mounts to the arms in the photo as in the photo above. But, the plow attaches to that frame, with pins like it does on a pick up truck. That allows it to hinge, so it can go up and down.
Most loader plows have a chain to restrict the amount the plow can go down. This plow doesn't weight 4000 lbs. So, I opted to put stops on the hinges instead. When the plow drops, there is a limit on the bottom how far, it can go.
My plow was derived from (2) Bolens tube frame, 42" garden tractor plows. They were from the 1960's and 70's. So, they are built well. And, not hard to find for sale, in the $35-$75 range.
I basically cut 15" of each side of one, and welded them on to the other. The pivot is built well. But, it needs to be beefed up for this application.
The original trip springs are heavy enough.
I always intended to add hydraulic angle to it. But, I found I only change the angle a couple of times when I plow. And, I could use the exercise. So, I decided to keep it simple for now.
The major advantage to a loader mounted plow, is the ability to push snow that is very high, from the top down. If I got 5' of snow, (sometimes I got drifts that high on lots of my driveway, before I learned how to use snow fence). I can set the blade 2' off the ground, and push the top half first, instead of trying to push it all at once. But, believe me I have had a mountain of snow moving in front of this thing. So, I normally just push it from the bottom.
If we get a lot of snow, and the piles get too high at the street, I can push the tops off, and lower them down to the height were my wife can see over them from her Civic.
I also often knock the top off the pile, the length of the drive, on the windward side, to keep the snow from filling in there, with drifts.
Yes, you can damage your loader, if you hit something. Which is always the case, no matter how you use it. But, that is why I like the Bolens plow. It is well built. But, not state plow truck, heavy duty. It can absorb some impact, and may break first, in the event of an accident.
The only damage I have had in 8 years, is the removable pin, that locks the angle can bend. And, that is by design.
No, I do not think it is a good idea to mount a plow directly on a GC loader bucket. The bottom of the bucket is not very thick. You would have to at least beef it up. The whole rig also gets too long.
I will go out and take some more detailed pictures today, and post them later on.
2005 Pierce Enforcer Fire Truck (A50323)
2005 Pierce...
Bron V75-3 Pull-Behind Hydraulic Vibratory Utility Plow (A49461)
Bron V75-3...
2003 STERLING ACTERRA 11FT FLAT BED (A51222)
2003 STERLING...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
1984 Trailmobile Enclosed Van Trailer (A51039)
1984 Trailmobile...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
