Best tires for the PT
   / Best tires for the PT #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
OK, I can go to the tire group and ask this, and probably will, but wondered what everyon has purchased here. I need a bar tire, would love a quad tire, but I have no learned they won't hold the weight (which I do not understand, must be something about the sidewalls). My tires, I think, are 26.12.12. Anyone care to weigh in on this?
   / Best tires for the PT #2
No. I got into a R1, R4, turf discussion here about 14 years ago and learned my lesson. :D
bwahaha.. OK, well let me make it easy on everyone. I need extreme agressive tread. Like I said, if I could put a quad tire on I would, but I guess they won't support the load (no clue why)
I see Carlisle, but I also see Deestone and Nanco, better price and what I percieve as a deeper tread.
   / Best tires for the PT #7
Carl,
The load ratings come from the number of plys, and the composition (steel, kevlar, polyester). You need a load rating high enough to support the tractor weight, plus load. For my 1445, that is 3300+1800=5100lbs/4 or at least 1275 per tire. ATVs don't run that heavily loaded, so the tires don't have the strength. Extra plys in the sidewall help keep you from rolling the bead off the rim, and from puncturing it. I doubt you would be happy with ATV tires from a durability perspective, given your conditions.
If you really need aggressive traction, I would recommend chains. I can't say enough great things about the ones Ken recommended. Just for the record, I'm running Carlisle R4, and I add chains if I know things will be tough, like mowing thistle on 20 degree slopes.
All the best,
Peter
Hey Peter. Yup, I got chains, run the year round. How my PT is set up is that the inboard tires are all Skidsteer, like 10 or 12 ply tires, and they seem just a bit shorter than the Carlisle. The outboard tires, that have chains, are nearly bald Carlisle balloon tires.
My chains are getting old though, starting to stretch and one has failed (and been repaired. Not sure how many more years I will get out of this set of chains... Like I said, year round use, makes such a difference but side slope there is no stiction beyond 35 degrees, get to 45 and there is major pucker, also coming off a 45 onto a driveway tends to mess the chains bad.
   / Best tires for the PT #9
I wonder if people ever read that you're doing 35-45 degree slopes... not percent grade. DEGREES. Good gravy that's steep! :eek:
Carl,
All the best,
Peter
So one thing on this load rating I need to get clarity on, they say that the quad tire is rated at 500lbs at 50MPH. So if you on a PT doing 8 does it change the rating?
FUNK'S G HYBRID SIGN (A58374)
FUNK'S G HYBRID...
2013 Chevrolet Traverse AWD SUV (A56859)
2013 Chevrolet...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
LOT: (3) NEW Hi-Run 26 x 12.00-12 Lawn & Garden Tires (A59076)
LOT: (3) NEW...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
