need help understanding pump mount measurments
/ need help understanding pump mount measurments #1
memphismark
california
Bobcat
Hey guys. I'm trying to find an SAE 2 pump mount that will fit face to face with a 22 HP gas engine. Surplus Center doesn't have it. Most seem to call for a 6.5 inch bolt circle. Closest circle on my 22 HP Harbor Freight Predator motor is about 6.375 (or 6 and three eighths inches) Measuring bolt circle from center to center or outside of bolt to center of circle (like bolt circles for the wheels on a car are measured), I can't find a 6.5 inch circle. Anybody got any ideas. Thanks much. memphisark
/ need help understanding pump mount measurments #2
Here is a page with the dimensions: Hydra Mount
Is your pump a two bolt mount?
/ need help understanding pump mount measurments #3
Run 2 bolts in the opposing holes and measure to the outside of one and the inside of the other. That is the simplest way for myself to get a accurate measurement if in doubt. The 6.500" bolt circle is a pem-g-flange, that seems to be the most common one. Harbor Freight should be able to tell you the mount also. I would say that is what you have. About the pump mount, is it a 4F17,AA, A,B,C and how many bolt holes? The only other thing you need to know is the 2 combined shaft lengths for the face to face spacing. CJ
/ need help understanding pump mount measurments #4
We need an update please.
Surplus center has several styles: Surplus Center
You could redrill to fit your engine.
/ need help understanding pump mount measurments #5
redrilling is only possible if the pilot diameter on the flange matches the motor. If the pilot diameters don't match it would be a real challenge to get the shafts aligned properly.
2014 Ford Escape SUV (A61574)
2014 Ford Escape...
2010 FORD TRANSIT CONNECT CARGO VAN (A59911)
2010 FORD TRANSIT...
Caterpillar 320B/BL/BN/LL Excavator Service Manuals Vol. 1 and Vol. 2 (A63117)
Caterpillar...
2015 Ford Escape SUV (A61574)
2015 Ford Escape...
Coleman Back Home Screen House (A62613)
Coleman Back Home...
2004 Dodge Sprinter 2500 Cargo Van (A61573)
2004 Dodge...
