MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,708
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
I was typing while Brian was typing. I consider him a master with his BB. If he says draft control improves BB function, I believe it
Thanks Richard,
I understand that many draft control systems work in just a slightly different way. Richard, you do not use your position control at all when using the draft setting?
I ask because I use both. After setting the desired sensitivity on the 3pt,(typically the most sensitive for me when finish grading) I use the position control to get the desired depth and set that lever. Then set the draft lever so that it just ever so slightly wants to start to raise the implement. (this also affects the sensitivity setting on my tractor) Set the draft lever at that point.
From that point on the draft is set and not touched until it is no longer needed. I use the position control to raise and lower the implement back to it's desired setting at the end of each run. In fact the manual specifically says to not use the draft function to raise the implement and to not have the implement raised for an extended period of time without disengaging the draft control lever, which is easy enough to do, just push the draft lever all the way forward in the down position. ( Draft stop is on the upside of the lever)
Anyway, just wondering, sounds like completely different draft systems, which leads back to my number one recommendation for everyone, READ THE OWNERS MANUAL.
