Mowing remove blades
/ remove blades #2
Pretty sure 30mm.
/ remove blades #3
I clicked on this thread to see what blades he was talking about and you already have it figured out and offered the socket size!!! You are on the ball today Larry!!!! :D
/ remove blades #4
Yeah, but is the OP asking about a MMM, Bush Hog type, flail (not likely), sickle, or (I'm out of ideas)? :)
/ remove blades #5
I trust my friend Larry's intuition..... I'm betting MMM. :)
/ remove blades #7
His info shows he has a BX1870, so my info was based on this. You can also do the change with n SAE, but it is an odd size and the fit is not quite as good.
/ remove blades #9
my answer would have been 'the size that fits'... but that's just me.
I usually just go to the tool box and grab a couple wrenches or sockets that look close, and use the one that fits.
Pete
/ remove blades #11
using impact wrenches on those socket sizes to remove blades? hope so, best
/ remove blades #12
Not to be a smart as$, but you use the socket that fits it. I have a Kubota lawn tractor, a B7100 ( is it still a lawn tractor? ) and a F series Kubota. I'm pretty sure they all take a different size. Then there is the other half dozen mowers. I prefer to use an impact wrench to drive the socket,
/ remove blades #13
I'm thinkin this thread should have stopped at post #2..... :)
/ remove blades #15
Or post #3 if it was from the OP. By the way, where is he (her)?
Were I a new member and got these responses I'd probably be silent as well. :(
/ remove blades #16
Not getting email notifications and doesn't know about the responses. :D
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
Rogator RG1300C (A63688)
Rogator RG1300C...
JOHN DEERE 5403 TRACTOR (A62130)
JOHN DEERE 5403...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
2005 Toro Z Master Commercial 72in Zero Turn Mower (A61572)
2005 Toro Z Master...
