muddstopper
I have ran across a manifold/accessory block I cant find any info on.
The valve is a parker, cse c132a. Block has some sort of flow control and is used to connect hydraulic tooling to using QC. There are three connections, one 10gpm flow, and two 5gpm flows. currently on has the connections installed for the 10gpm and one 5gpm connection.I believe the 5gpm flows are fixed flows while the 10gpm flow can be adjusted by the large knob. Thats about all I know about this accessory block. Any help id'ing and maybe a little info about just how this part is supposed to work will help me decide if I want to go thru the trouble to try and salvage it for another project. If someone has a link I can visit I would appreciate if you could post it.
