Varmints in the machine
/ Varmints in the machine #1
mikerose
Member
Dartmouth, MA
Kubota BX-23
I went out to use my Kubota BX today, after not using it for nearly two months, and discovered to my dismay that some critter (likely a mouse) had made a pretty good sized nest on top of the battery. Big project to get it all cleaned out. I'm sure I'm not the only person who's run into that, and it's not even the first time for me. Any defense?
/ Varmints in the machine #2
Big problem. Next they will be chewing your wires. I put some traps in a few places when I have to leave mine set outside for a long time.
/ Varmints in the machine #3
Trapping mice is an ongoing chore at my place. The outbuilding where various machines are stored is continuously invaded by mice. I use a combination of poisons, but the common mouse traps is my favorite, except for the continuous chore of rebating them. Even in the mild winter that we are experiences here, the mice keep on coming. You are lucky they didn't chew up some wires as daves mentioned above.
/ Varmints in the machine #4
Keep the hood open when not in use...Put 4 or 5 dryer sheets around the motor. It works for me.
/ Varmints in the machine #5
Just pee on the battery. The smell will keep them away.
(I mean the smell of burning pubic hair and feces :))
Interesting!! I admit I've never heard of that, I might just try that. Thanks.
/ Varmints in the machine #8
We had a bird nest on the exhaust manifold of a Farmall A. It was right up against the gas tank. We found it when we were cutting hay and it caught on fire. It was a little exciting for a bit and dad had some burned fingers pulling it out of there. Ed
/ Varmints in the machine #9
I use WD40,good heavy spraying here and there.
/ Varmints in the machine #10
I sprinkle a few drops of concentrated peppermint oil under the hood. This seems to work well in repelling mice. And, when you start up the tractor, it smells like a candy store! You have to do this every month or so.
/ Varmints in the machine #11
I tie little bags of moth balls under the hood, seems to work well. I also put them in a camper which had several mice & they left after.
/ Varmints in the machine #12
I use a combination of moth balls, leaving the hood open and a 5 gallon mouse trap. The last time I checked there were 20+ mice in the pail. I dump it and bait in again. In a week or so I check it and usually have a bunch more.
/ Varmints in the machine #13
You should probably get a cat.
/ Varmints in the machine #14
"VARMINTS"??? Poor choice of term, but otherwise, some good advice. I have found leaving hoods open, where practical, works. Moth balls seem to work, as well. Cats, ditto. I can tell you from experience that mice can do major damage to pickup truck wiring! Major! They haven't infested my diesel tractors, but garden tractors are a problem. I did make a nice cozy place in the barn for our cats, as well as a cat door, so the mice don't have a free ride in the barn. I think that the cloth strips I hung at the cat opening deters raccoons. Always something.
/ Varmints in the machine #16
Had one die in the duct work of my Kubota, that was special for a few weeks ! I put bate chunks out, moth balls and the latest find is they don't like fluid film. Be great if that is the answer !
/ Varmints in the machine #17
I had mice infestations in my barn for years. I went through cat after cat, but the owls get the cats every 6 months or so. Finally last year I started buying the solid wax mice bait blocks from tractor supply in small pails. These blocks have a hole drilled through them. I run them on a wire inside of 3" steel pipe sections (about 18" long) to keep them out of the reach of dogs and other non-target animals. I put these all around my barn and outside. At first, I found lots of dead mice, but the bait blocks would be eaten in a few days. I kept replacing them, and slowly they started lasting for a week, then a month. I had effectively reduced the mice population to very low levels, and have had no problem since. Periodically I rebate the pipes, but now it's not very often. I plan to keep these pipes filled with mice treats continuously. It works, but I have to keep up with checking the bait stations.
/ Varmints in the machine #18
I have 2 cats on guard duty 24/7 I have cat doors on all 4 of my outbuildings and the cats can come and go (no more mice)
/ Varmints in the machine #19
I use the green Tomkat rodent blocks in the white tub at the ag store, which are weather resistant. I keep 2 or 3 under my tractors parked under the sheds. If I had a tractor I left out in the open for extended periods, I'd put a few around any compartment that looks to be a good place to build a nest. I used to keep my PU under a shed near the house but a squirrel decided to work over my wiring harnesses. Put some of them under the hood where the battery is located and more in the spare battery tray (for a diesel engine which I don't have) and have had no more problems.
On TomKat brand, I keep them in key areas around the place and they work great....other than having to deal with the smell of decaying flesh from time to time....grin. On my house, I feed them before they make it into the house which works extremely well (pier and beam). Any feed or seed stored in a shed or building get some around it. No I don't have any little kids around nor loose pets. Works for me.
/ Varmints in the machine #20
If you have a cab tractor, this stuff works great, and smells great too!! Have bad trouble with rodents on the combine. They chew up lots of wires and pee everywhere, including on that $350 circuit board in the arm rest controls!
Object moved
17395SFL (A61568)
17395SFL (A61568)
2013 Kubota BX2370 54in 4x4 Compact Utility Tractor Mower with 48in Rotary Brush Cutter (A61572)
2013 Kubota BX2370...
2002 CATERPILLAR 247 SKID STEER (A64279)
2002 CATERPILLAR...
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
2025 JMR 4x8 Forklift Safety Basket (A61572)
2025 JMR 4x8...
2009 John Deere 1770NT Planter (A63111)
2009 John Deere...
