Help - L2850 Battery Alert Light ON - Why
   / Help - L2850 Battery Alert Light ON - Why #1
Popster
Southern Maryland
Kubota L2850, 8N
My L2850 battery alert light would come on after start-up, then flicker after a few minutes, then go out. The manual claims that this indicates low fluid level in the battery.
My nine year-old battery which was a cheap replacement battery that was installed in the tractor when I bought it finally died just before this snowstorm in the Mid-Atlantic. I replaced the battery.
The tractor starts instantly and runs great. Only problem is that the indicator light never goes dim or goes out.
I plan on taking a voltage reading with the tractor off and then with it running to see if the alternator is putting a charge into the battery. I have run the tractor at least 6 hours clearing the neighborhood driveways and loading firewood.
Anyone know what is going on with this light?
Note: The terminals are connected and there is an small wire going to the negative terminal.
Any help is appreciated!
I've learned that there is a sensor that Kubota put in the #2 cell that monitored the electrolyte fluid level. There is a white small wire attached to the (EDIT) NEGATIVE terminal of the battery. With the old battery (not a Kubota) the light was out initially, then over time would be on for a bit, then dim, then go out. I learned that this is because electrolyte level got low. Now with new battery, the light is always on.
Any ideas?
Any ideas on how to jumper it off?
EDIT - The wire is to the negative terminal, NOT the positive
   / Help - L2850 Battery Alert Light ON - Why #3
Any ideas?
I have an l2850 with a non kubota battery, so no place for that kubota sensor. I have no wire but the ground strap going to the negative terminal. Try disconnecting that white wire and see if the light goes off. The air filter switch is similar- it grounds out to make the light come on.
   / Help - L2850 Battery Alert Light ON - Why #4
Make sure your alternator is putting out enough... and the belt is tight
2016 CATERPILLAR 325FL CR EXCAVATOR (A52705)
2016 CATERPILLAR...
2003 Big Tex 10PI...
Ford Super Duty Pickup Truck Bed (A55973)
Ford Super Duty...
16001 (A55853)
16001 (A55853)
2014 VOLVO VNL (A55745)
2014 VOLVO VNL...
2015 Dodge Journey SXT Van (A56859)
2015 Dodge Journey...
