Three point hitch
/ Three point hitch #1
presnewt
Thomson, Ga
Steiner 440,Kubota MX5400 HST cab
can anyone give me an idea as to cost of three point hitch for steiner or ventrac? does anyone use them to pull small disc harrows or blades? thanks
/ Three point hitch #2
You probably will not be happy trying to pull a Disc Harrow nor Rear Blade; both in the category of ground contact work.
It is the tremendous mechanical advantage and contact patch of large rear wheels which make ground contact implements effective on traditional tractors.
Even so, ground contact work puts a considerable strain on geared tractor drive trains. Ventrac/Steiners have belt drive, not gears, and probably cannot pull anything heavy enough to penetrate the tough red clay I see traveling in Georgia.
The lightest Disc Harrow which is effective on previously plowed ground has 18" diameter pans and weighs 600 pounds, in my opinion. The minimum traditional tractor that will satisfactorily pull one is around 1,900 pounds, tractor only, with 4-WD and those large rear wheels.
I question how the small wheels/ low ground clearance on V/S would cross plow furrows, pulling a Disc Harrow.
A roto-tiller would be a better option than a Disc Harrow.
/ Three point hitch #3
Ventrac 4500 3pt hitch kit plus hydraulic valve kit required goes full retail at abut $2500.00 if DYI.
prs
/ Three point hitch #4
Jeff, where did you get your information that Steiners and Ventrac are belt drive? Mine is gear drive trans axle at both ends…. only belts on the alternator and a second hydraulic pump plus the power take off in the front …….. jim
/ Three point hitch #5
I reckon I am going to have to do some more studying. MEA CULPA.
jeff9366
/ Three point hitch
jeff9366
so does that mean that a ventrac or steiner might be able to pull a small harrow or blade? anyone out there had any experience? i mainly ask because i have a gravel driveway that requires scraping, i would love to own the power rake but they are expensive. i would also like to use a harrow to plant food plots for deer.
/ Three point hitch #8
I could have bought a (like new) 3ph a while ago, quite cheap and I turned it down. One, I don't like 3point hitches to begin with and the hydraulic issue was a hassle. It is something of a step backwards on a steiner if you ask me.
The Steiner has impressive pulling power for the size of machine.
I was contemplating building a long grader frame out front with a salvaged 3ph blade for playing on my driveway. I am just a little bit leary about eating the dust.
/ Three point hitch #9
I am trying to find the power rake as well, even though I have a big one (Harley PRO 8). Yes, they are pricey and hard to find.
This stone filled roller weighs a lot and is probably a bit much for the machine. I was rolling grass seed and turned coming out of a hill just a little too soon. It pushed the machine out from under me. My first tractor rollover (kind of) ever.
/ Three point hitch #11
When I click on the attachment link, I get an error message.
Which tractor rolled?
/ Three point hitch #12
I have been thinking about adding a 3 point hitch on mine. They are cat. 1 by the way and have been looking at rear blades with off set and a box blade?jim
/ Three point hitch #13
I have a 3-point hitch on my Ventrac 4500Z and several 3-point implememts. The most useful are those designed for carrying and lifting applications such as the pallet forks as compared to draft applications such as box blades and scraper blades. The most fundamental issue is that the tractor is built so low to the ground for stability when mowing on slopes that the 3-point hitch arms are only about a foot off the ground when horizontal in the normal working position for draft applications. Most 3-point box blades, scraper blades, plows, disks, and cultivators are designed for much higher hitch points. So even though it is possible to attach them by adjusting the lift links, the result is the implements cannot be lifted very high for transport. Often this can be overcome by using a hydraulic top link. I do use an EA 4 foot box blade and an EA 6 foot rear blade, but they only work because of the hydraulic top link to tilt the implements for adequate ground clerance. The tractor has no difficulty handling these implements.
/ Three point hitch #14
Not sure why the first picture disappeared.
/ Three point hitch #15
Ouch. How did you get it upright? Any damage to the tractor? Did you have to remove fluid from the combustion chambers?
/ Three point hitch #16
Industrial Toys, I reckon we are safe to assume that roller is full of ballast.
When I was a lad of 13 we harvested our own hay. Our International 424 tractor was 2WD. We had a long open platform trailer 8'X20' which steered by the front axle as you towed it. I had a good bit of freshly bailed hay on the trailer and had some more to load out of the lower field. The lower field was, well, lower and it sloped at about 20 degrees. 2WD tractor with AG tires going down hill with heavy trailer pushing. OH WHAT A RIDE I went for when the weight transferred to the front tires of that tractor. It was a large field with no obstacles, so I got it stopped eventually. Jack warns of that kind of thing in one of the online videos.
prs
/ Three point hitch #17
What category hitch does Ventrac put on?… jim
/ Three point hitch #18
It is a cat 1. Not sure of the lift spec at the ends of the draft links though.
prs
/ Three point hitch #19
Investigators say "Speed Was A Factor"
I have duals and should have used them. Never even crossed my mind. For the steepest sections, I was backing up the hill.
/ Three point hitch #20
The tool box got slightly bent and I have yet to figure out a way to make it near perfect. How does one take take out a crease?
I uprighted the machine and let it sit for a while. Then disconnected the fuel solenoid and cranked the engine to make sure it did not have a hydraulic lock. No harm done.
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
2013 29ft. Larson LXI292 Boat with 2007 30ft Loadmaster T/A Boat Trailer (A61574)
2013 29ft. Larson...
2023 Kubota L6060HST Compact Utility Tractor (A63688)
2023 Kubota...
2017 Hyundai Elantra Sedan (A61574)
2017 Hyundai...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
2018 SHERP PRO1000 AMPHIBIOUS ALL TERRAIN VEHICLE (A63276)
2018 SHERP PRO1000...
