What is a tire, wheel, rim?
   / What is a tire, wheel, rim? #23
And what about water pump pliers? Channel lock pliers.
Johnson bar/breaker bar/strong arm and the list goes on and on and the proper NORTH AMERICAN spelling for a tire is tire
That's what I said Mate, "And then I throw a spanner into your NA works and spell it tyre."
   / What is a tire, wheel, rim? #24
My tires are tired of being tires because its very tiring being a tire.
   / What is a tire, wheel, rim? #25
It may not be correct but I tend to think of a tire as the rubber part, a rim as the metal part and a wheel as the entire assembly .....
Now, as far as some of the other things mentioned in this thread:
I always understood a Monkey Wrench to be like a pipe wrench but without teeth. It is for turning fittings and/or things with heads. A pipe wrench is for turning/holding pipe, therefore it needs teeth to bite into the pipe. A pipe wrench can cause unwanted damage to brass fittings
Now, as to a "left-handed" one ... well, that is entirely another subject
   / What is a tire, wheel, rim? #26
   / What is a tire, wheel, rim? #27
It is a good thing I understand Brit to a certain extent. I also can usually understand other peoples misspelling.
   / What is a tire, wheel, rim? #28
Bikes need help to stand up because they are two tired.
   / What is a tire, wheel, rim? #30
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A54811)
2015 Toro Multi...
2023 BOBCAT T770 SKID STEER (A52705)
2023 BOBCAT T770...
UNUSED RAYTREE RMBD50 - 50" DRUM MULCHER (A54757)
UNUSED RAYTREE...
2017 Nissan Frontier Pickup Truck (A55788)
2017 Nissan...
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A53843)
2016 FREIGHTLINER...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
