Digging a hole..?
/ Digging a hole..? #1
hunt4570
Super Member
South Carolina
Grand L3540 ,724 loader, bucket, grapple and now forks also! And just for OP.. a pool!
So I'm having a concrete slab removed from an addition we tore off of the house. Expensive to have that concrete hauled off so I'm wanting to dig a hole to bury it. I've never tried to dig a hole with any of my tractors, but I'm sure it can be done, right?
I have a Kubota 3540 with the 724 loader, my soil is very sandy and easy to dig. Just a longish trench should work I'm thinking maybe 5 feet deep or something. Enough to lay the concrete in then cover it up when I'm done.
Whats the best way to go about this? What are the pitfalls to look out for?
Thanks.
/ Digging a hole..? #2
In our city it would be against the law do this.
How big will the pieces be about?
Do you have low spot that collects water,or enforce banks?
5' feet should be more than enough,but length I would want long to spread concrete....not a pile.
/ Digging a hole..? #3
We are in very rural area and buried concrete and asphalt is a major no-no.
They claim it is to protect the ground water table.
It is permitted to use crushed concrete as a road topping same as crushed stone would do.
In fact crushed concrete makes an excellent road base.
/ Digging a hole..? #4
I had a very similar situation. I recommend putting an ad up on CL for free fill. You will find someone that needs it. I had a guy with a backhoe and dump truck take about 10 loads from my property. Wouldn't recommend burying it - not permitted in most areas.
/ Digging a hole..? #5
Digging a hole with most tractors takes a while but can be done. Not very politically correct but after it is buried, who knows? It is a hunk of rock, not nuclear waste.
/ Digging a hole..?
Interesting, I never thought it would be a problem to bury it.
And then someone said to advertise it as fill on craigslist(I might try that) but isn't that just someone else burying it?
And I'm in the middle of nowhere and have 100 acres..
/ Digging a hole..? #7
You should be fine at that depth. I have a backhoe and tend to dig my pits as deep as I can out in the middle of a pasture where I'm 100% sure I will never need to dig there again. I also have a SDS Max drill that does a fair job as a jack hammer and I like to use broken up concrete for filling ditches that are eroding. For slabs of concrete, I've also used them to line the banks of the creek where it's starting to erode into my land.
/ Digging a hole..?
My problem with using it as erosion control is where my erosion is, I cant get my tractor to it. Or I'd for sure be doing that..
/ Digging a hole..?
And why am I not getting notifications of these posts. I used to, and I've not changed any settings..
I just looked and it still says instant email notifications..
Hmmmm
/ Digging a hole..? #10
I can understand politicos not wanting asphalt buried due to the very slight degree of leaching possible from it, but concrete. What contaminates would that consist of AND what difference is it in completely burying waste concrete vs having millions of tons of it in slabs for houses, roads, pilings that go below the water table, etc. Just plain stupid to say that it might contaminate the water table as a reason to not bury it. I see no difference in concrete and a large rock as far as pollution is concerned.
Now as for burying stuff in general, I have done some of that but it isn't in my opinion "best practice". If it is possible to recycle it in to crushed for road beds or even to place it for erosion, that is the best utilization of resources. Alternately placing it as structural fill for land reclamation is also a good idea.
/ Digging a hole..? #11
In answer to your original question, Just start "peeling a layer at a time with your FEL in a trench.
Move over a few inches and peel again to make the trench wider so you have plenty of clearance for your tires.
Keep peeling the top layer and stacking it at the end. Watch your angles, make the ramp your are creating shallow enough that you can easily back up it each time.
As long as you don't hit rock that you cannot move, you can dig as deep as you need , but the ramp will just get longer and longer to keep the angle you can climb out of. At some point you will not be able to stack at the end, and must carry your peeled up dirt out backwards. This will further unweight your rear tires, and make the ramp accession backward more difficult. Be sure to have rear ballast. I don't see any reason to bury it very deep. What would be wrong with just burying it at surface level? Have a nice flat pad to use for something else.? I also don't understand the pollution angle on concrete slabs.. What pollution?
/ Digging a hole..? #12
As James said, just keep working a trench the width of your machine. A tooth bar on your bucket would be quite useful as would a set of rippers on a box blade.
Start like this: https://www.youtube.com/watch?v=svJTH7x7OLs
and keep going as deep as you need: https://www.youtube.com/watch?v=ze8mPB7A8uU
Be aware of where your water table is for how deep you can dig. I'll be doing similar but have to wait until the middle of the summer so it doesn't fill with water before I'm done. I see no difference in the environmental impact of a foundation of concrete 5' down vs burying the demolished slab 5' down.
/ Digging a hole..? #13
When we were building the pad for my tin shed, we dug up someones buried rock pile. What a mess, we lost our footing and had to dig deeper and do more compacting work. We also found someone else's outhouse. That brought up a lot of glass bottles and ceramic pottery which was more labor to remove so nobody got hurt. Some previous owner of my property years ago said, "lets bury it here, no one will ever know".
/ Digging a hole..? #14
We pushed in a concrete foundation from a previously burned up home. Then used fill dirt over top. The only real issue we have / had is part of the foundation was not buried deep enough so some of the concrete is now getting exposed due to normal soil erosion. The other part of the issue is settling / underground washout. We have a lot of water in our area and I feel that the broken up concrete has made a nice path for water to change direction in. There is some evidence of water leaking out, as well as the once big mound is now settling to a divot.
But then again, this was a 1500 sq ft house with a basement.
/ Digging a hole..? #15
/ Digging a hole..? #16
Burying the concrete is not wrong or harmful but you do want to get it deep enough so it doesn't resurface. It can make a good base for a lane especially if there is a persistent low spot.
/ Digging a hole..? #17
I would pile it in an out of the way place.
It will come in handy in the future.
I have a pile from a project last year and have used some already. :thumbsup:
/ Digging a hole..? #18
Best idea yet. I had several concrete slab pieces left on this place when I moved in. I have used all but one of them for something.
/ Digging a hole..? #19
You could use it for a wall, like this.
Bruce
/ Digging a hole..? #20
Bruce
My father would roam the city in a VW van and bring home broken sidewalks and driveway anytime someone would be replacing one. He made many retaining walls and flower beds with broken concrete just like that. He even made steps down a 90' embankment down to the lake in our back yard with that. Something like 150 steps down. It looks really nice when done. He planted English Ivy on most of the walls. :thumbsup:
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
2014 International Garbage Truck (A61573)
2014 International...
2007 JLG 600HJ 60ft 4x4 Articulating Boom Lift (A61572)
2007 JLG 600HJ...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2014 Ford F-150...
INTERNATIONAL 490 - 21' DISC HARROW (A63291)
INTERNATIONAL 490...
2016 Ford F-650 18ft Hydraulic Dovetail Hauler Truck (A61573)
2016 Ford F-650...
