Pat's Easy Change Pat's Easy Change System - Order Online!
   / Pat's Easy Change System - Order Online! #661
Loving mine! Ordered them and Brian at FitRite helped adjust my ordered hydraulic top link to account for them. These are the best money I've ever spent!
You might want to consider getting some shorter mounting bolts (they are 5/16" or 3/8" I think) that are grade 5.
The bolts included with the kit are grade 2 junk. They are also too long.
The included junk bolts will break off, or the threads will strip, likely leaving you with an extractor job.
Other than the bolts, the Pat's kit is absolutely great!
   / Pat's Easy Change System - Order Online! #662
Yep, did that a few days later when I had more time!
   / Pat's Easy Change System - Order Online! #663
My washers keep popping off implements. Most recently on a scraper blade while I was backing up. 1 side dug into dirt, bent blade, pto cover, pats easy hitch, and almost popped a tire (not sure what else it did). I'm about to take them off. I've tried a variety of retaining clips and problem continues. Any suggestions would be appreciated.
   / Pat's Easy Change System - Order Online! #664
Try this. The OEM Pat's can be modified by using one washer. The others are from parts.
Also, the OEM Pat's seem to hold better if the lynch pin is inserted in the non-bent end. The ring is more secure.
One more thing, the black lynch pins from Tractor Supply are VERY strong compared to the gold colored ones.
CountyLine Lynch Pin, 7/16 in., Heavy Duty, S:p913TSC - For Life Out Here
   / Pat's Easy Change System - Order Online! #665
Those are good ideas and thank you! anything I can go to the store and buy?
   / Pat's Easy Change System - Order Online! #666
All of the components are available in any hardware store. I used grade 8 washers for the most part for the large washers but it is not really that necessary.
Take your OEM Pat's washer in to compare hole size and washer diameter for your implements (it is different for CAT 2 lift pins). Use a lynch pin to determine the correct size for the small washer.
Tractor Supply should have everything you need. They sell washers by the pound.
Put the small washers in a vice and pound them over with a hammer.
   / Pat's Easy Change System - Order Online! #667
The product is fine but do not buy from Pats website because the return policy is a joke, no spacer bar, plus you will pay about $60 more than if you bought from Rural King, even Amazon is a lot less.
   / Pat's Easy Change System - Order Online! #668
So is Agri-Supply (ASC) cheaper than most. Certainly cheaper than the manufacturers website. Pays to shop.
   / Pat's Easy Change System - Order Online! #669
I don't have a welder are you using welder or composite like JB Weld.
NEW Thiessen Track Closer Disk (A56435)
NEW Thiessen Track...
2023 RTVXG-850 SideKick (A56435)
2023 RTVXG-850...
LOT: Cutters, Shears, Giant Chalk Line, 100' Tape Measure (A59076)
LOT: Cutters...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56435)
2006 Heil Tanker...
2009 Yale Veracitor 135VX 12,150lbs Straight Mast Forklift (A56857)
2009 Yale...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
