Removing TYM 273 steering wheel
/ Removing TYM 273 steering wheel #1
jbarr2
Cottonwood, CA
TYM T273
Have a leak and need to remove steering wheel. removed cover and retaining nut now?
/ Removing TYM 273 steering wheel #2
jbarr2, Hi. I have not removed my steering wheel, but I had once asked this same question and Myazz went ahead and pulled his off. Using a "large" puller. It didn't look like it came off easily but it did come off. If you search my threads, you should find some good info per this. If I remember correctly he even posted a couple of pics. Good luck, Greg
/ Removing TYM 273 steering wheel #3
Gregster- You have a better memory than I. I remember seeing this thread and thinking I pulled the steering wheel on the TYM but then I talked myself into it being the old Kubota I had. Well, you were right.
Here is a link to my post on pulling the steering wheel.
http://www.tractorbynet.com/forums/...ill-next-problem-post2045746.html#post2045746
Rubber mallet might be helpful too. I think I could do it without the puller.
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A61568)
2015 Ford F-150...
2015 Nissan Quest Van (A61569)
2015 Nissan Quest...
4004SFL (A59228)
4004SFL (A59228)
CHALLENGER VACUUM PUMP (A60736)
CHALLENGER VACUUM...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
