Kubota LA350A FEL Capacity
/ Kubota LA350A FEL Capacity #1
TimP
Kingsville, MD
B3000HSDCC
Hi All.
I have a B2150 with a LA350A FEL.
I want to get some of those Titan clamp on forks, but am unsure of my loader capacity.
I planned to get either the 1,500lb or the 4,000lb capacity forks. But no sense paying for 4,000 forks if my FEL will only lift 1,000lb.
Any comments on the chain binders as an option for the forks ?
Thanks for the help !
Regards, Tim
/ Kubota LA350A FEL Capacity #3
The model number gives the capacity in kg (take first two numbers and multiply by ten; the last number gives the revision) -- so it would be 350kg, or about 772#. And that's at the pin. Farther forward, you will lose capacity. Clamp on forks are especially bad for that.
The only reason you might want to get the heavier forks is because of their construction. If I remember right, the lighter forks are a bit wispy built.
/ Kubota LA350A FEL Capacity #4
You're loader lifts less than 1,500 pounds. By the time you put on a set of clamp on forks your lift capacity will be drastically less than 1500 pounds. It takes no slouch of a tractor to lift 1500 pounds at 48" forward of the pins.
/ Kubota LA350A FEL Capacity #5
Go with the "wispy" 1500. I've got both Titans, 4K rated forks for my M4700 and 1.5K rated forks for my B7610. Both sets are very sturdy. Also either get the stabilizer bar or fab something up, it really helps.
Thank you all for the replies and info.
I appreciate it !
Regards.
/ Kubota LA350A FEL Capacity #7
BUT don't forget 4570, if you drink some CUT kool-aide, you will be able to pick up 3500 pound logs! lol
SR
/ Kubota LA350A FEL Capacity #8
SR
Just like this! :cool2:
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A62129)
2007 CATERPILLAR...
2019 TerraGator 7300 Spinner truck (A61307)
2019 TerraGator...
2020 Deere 317G (A60462)
2020 Deere 317G...
MMS 750 Remote Control Lawn Mower (A60463)
MMS 750 Remote...
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
Giyi GY-STB47 QA Telescopic Boom (A60463)
Giyi GY-STB47 QA...
