Non-standard grease fitting threads?
/ Non-standard grease fitting threads? #1
SugarPeaFarm
Doyle, TN
Mahindra 4530 4WD
Has anyone done enough research to find out what size and thread pitch Mahindra uses for their grease fittings? I have a 4530 and the nipple portion is gone on the front zerk on the front axle pivot. It measures .375" outside thread diameter and 28 tpi on a thread pitch gage. Threading is straight, not tapered. 3/8"-28 is apparently used in some places, but I can find no US source. I have called my dealer, Mahindra parts in Houston, and several other local Mahindra dealers and no one knows what thread they are, and no dealers stock them. All can special order for a $2 part. If I never expected to need another zerk for this tractor I would not bother, but there are a lot of grease fittings on these tractors and they are not all the same. Here is a picture of the damaged fitting.
/ Non-standard grease fitting threads? #2
Bummer. Hope you can figure something out. I've probably got 100 new Zerks of considerable threads types on my shop shelf, and I guarantee you the next time I need a replacement I won't have the right thread type......... :mad:
/ Non-standard grease fitting threads? #3
I recently bought fittings for my car's ball joint grease point at my local Ace Hardware store. I took the old zerk with me and at the store was able to screw it into the proper size gauge they had. Although they didn't have the angle fitting I needed, the chart gave me the exact size and thread pitch. From there I made my way to the closest auto parts place and picked up an assortment in the correct size: two straight, two 45 degree and two 90 degree, all for about $4.00.
When I first bought my tractor, I noticed the loader was missing a fitting on one of the cylinders. Of course at which point I wondered about the dealer prep. Choosing one I had on hand in my shop, I tried inserting it into the empty threads. Well, to my dismay, there were no threads to be found. What I discovered is, by slightly taping in the lube fitting to the point of purchase, I was able to slowly turn it fully into the opening, as if it were self-tapping. Problem solved.
/ Non-standard grease fitting threads? #4
Off thread a bit, but I tore one out of my Arctic Cat rear suspension, and i cant figure out the size. Just buy an assortment? I can use them on the tractor and implements as well I'm sure, right?
/ Non-standard grease fitting threads? #5
Well, it's not quite that simple. In your case you first have to figure out whether your machine is generally standard threads or metric threads??? Then you have to know the thread count??? See how frustrating that is. I'd do as someone described earlier, take out a "like" zerk and go to the parts store for a measurement of the size and thread count. Then, with some luck, you'll get close enough that you might get the right zerk. This dilemma is why I have enough zerks to last me three lifetimes, if they were all the right thread size that is!!!! :)
/ Non-standard grease fitting threads? #6
I will look in daylight and if I have what you need I will PM you for your address and mail it to you.
/ Non-standard grease fitting threads? #7
Thanks, great idea!
After spending most of Friday afternoon on the phone with Mahindra in Houston, I am a little farther along. I sent them a picture of my fitting and it's measurements, part#, etc. They pulled one from their inventory and sent a pic back to me. It is the same, and I my dealer has ordered the part for me. Mahindra did not know what thread pattern it is, but has promised to find out. I found at least 7 different part numbers for grease fittings in the parts breakdown, most of them are metric, a couple have no thread ID in descriptions. I have asked Mahindra to provide accurate thread sizes for all the grease fittings for my model tractor. Or at least a kit with all the correct ones with part numbers. The one I need now is over $4 from Mahindra, which is approaching the Deere pricing model. If I am successful, I will share here.
/ Non-standard grease fitting threads? #11
Most grease fittings on Mahindra are metric. I source mine from my local auto parts store. Much cheaper than Mahindra.:thumbsup:
Not considering the FEL, my tractor has 9 different part numbers for grease fitting. Most (6) are metric, two have no identification that indicate thread patterns, and one is the one I needed. They did send me a couple but have not shared the thread size so far. At least i was able to put a new one on.
/ Non-standard grease fitting threads? #13
Are you sure it isnt 27tpi? a common 1/8NPT is pretty close to 3/8" diameter and sometimes hard to see the taper.
Other than that, perhaps the upper portion is common? Usually when I break one like that I'll just grab a 90 or 45 degree fitting and swap the upper portion.
Nothing metric is even close to .375. 9mm is too small and 10mm is too big.
/ Non-standard grease fitting threads? #14
I have an KIOTI NX4510 and while greasing the front end loader fittings, one came out and low and behold, the threads where rounded off. Dealer has no info on thread size, I have a thread guage, 27 tpi taper. I believe it is a standard 1/8-27 taper pipe thread. Having difficulty finding the right tap. Will do some more hunting tomorrow. Wish the good hardware stores still existed!
/ Non-standard grease fitting threads? #15
28 tpi can be 1/8" BSPT or 1/8"BSPP. Kioti is fond of 1/8"BSPT and I also have them under a Hyundai (industrial) part number.
/ Non-standard grease fitting threads? #16
Could be. I'm not familiar with British stuff. Just never run across it or use it. If that's indeed what it is shouldn't be hard to find
/ Non-standard grease fitting threads? #17
Just to conclude my above contribution, the zirk fitting thread is a standard 1/8 pipe thread- taper -27 threads per inch. While I was at it, I checked the rest of the zirk fittings and glad I did as most all needed snugging up. Hope this helps others who may have inquiring minds.
/ Non-standard grease fitting threads? #18
I know this is an old thread but I am still having problems finding grease zerks for my Mahindra 4530. I am specifically looking for the one that goes where the 4wd front drive shaft comes in to the front axle.
Can anyone help?
/ Non-standard grease fitting threads? #19
Sorry, I have no specific info. I usually take an old zerk to the hardware store and they find one that’s the right size, shape and threads.
Most of the “bad” zerks really only need to be taken off and cleaned with a wire to get the old dry grease out that is plugging it or sticking the spring and little ball valve. Once you get it cleaned out and pump some new grease through, it’s good to put back on.
If it’s not the zerk, taking weight off the joint your trying to add grease to helps also.
/ Non-standard grease fitting threads? #20
Just buy a variety pack of metrics and one of standards. I've got several boxes.
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2007 Volvo VNL Truck Tractor (A63689)
2007 Volvo VNL...
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
MASSEY FERGUSON 4710 TRACTOR (A64280)
MASSEY FERGUSON...
2008 Ford E-350 Cargo Van (A61573)
2008 Ford E-350...
