Recovery point metal thick enough?
/ Recovery point metal thick enough? #1
NS Gearhead
Nova Scotia, Canada
Deere X350
Had to drill this to fit into my truck's receiver. There's still 7/16" behind the pin at the thinnest point. Solid 2x2 stock. Pin is 5/8", shackle's 3/4", strap's rated for 27,000lbs, truck is 9,200lbs, plus 1,000lb plow, plus 190lb frenchman, plus, plus, plus. The lower one I bought today at Princess Auto thinking it would work, but had the same problem. Figured I'd drill the old one and return the new. Anyway, what do you think? Use it or get something else?
Thanks.
/ Recovery point metal thick enough? #2
Seems like your receiver is very shallow. Is there an obstruction preventing it from going further in?
/ Recovery point metal thick enough? #3
If you break it, you have bigger problems than a broken hitch.
/ Recovery point metal thick enough? #4
I think you will be fine. I would expect the pin to shear first.
/ Recovery point metal thick enough? #5
Do you weld? Put a pin in the unused hole, cut it flush and put a spot of weld on it to keep it in place when you remove it.
/ Recovery point metal thick enough? #6
What would be the point of this?
/ Recovery point metal thick enough? #8
/ Recovery point metal thick enough? #9
I think you would tear the holes in the receiver before the insert tearing out the back. Here is mine, 2x2 solid stainless.
/ Recovery point metal thick enough? #10
He has to use the back hole. He drilled the back hole because the other hole didn't allow enough clearance.
Ok. I thought he was using the front hole. That back hole had a lot of meat left behind it.
/ Recovery point metal thick enough? #11
There might be a lot of meat behind the rear hole, but if there was ever an accident and a lawyer saw that stinger, there would be a huge problem.
I would correct the problem with the receiver.
/ Recovery point metal thick enough? #12
Very good advice.
What looks good, works good don't count when certification is looked at.
No, nothing. A regular ball type insert works no problem. The shackle is actually what hits the very end of the hitch... and only needed to go in another 1/8" maybe... but I don't have a machine shop. LOL I suppose if I would have put a 5/8" shackle in it would have worked...
I've talked to some welders and people I trust and they think it should be no problem. I think the truck's hitch is the limiting factor here. It's only going to be used if I plow too far into a snow bank and need a tug back.
Thanks for the replies guys.
There's no problem with the receiver... and I'm not sure what you mean by "stinger"?
/ Recovery point metal thick enough? #15
Some of you really like to overthink things. It’s fine. As mentioned, the pin will shear long before that rips out.
/ Recovery point metal thick enough? #16
Some of you really like to overthink things. It痴 fine. As mentioned, the pin will shear long before that rips out.
Overthinking ?? Is the alteration made by a certified person or inspected by one is what counts.
/ Recovery point metal thick enough? #17
Yes, overthinking. Certified for what? Do they have Tow Strap Certification in Canada now? :rolleyes:
/ Recovery point metal thick enough? #18
The original manufacturer will be able to state it was made under controlled conditions to certain specifications including engineering design. Alterations after that have changed it. It is not the same item anymore.
