Echo 18" CS420 - Chain keeps popping off and getting burred up...
   / Echo 18" CS420 - Chain keeps popping off and getting burred up... #21
Well, this is very basic and NOT intended to offend; are you holding the nose end of the bar upward before and during the tightening of the bar bolts.
prs
   / Echo 18" CS420 - Chain keeps popping off and getting burred up... #22
I found the paper...
It says it fits Echo 18" CS400, but the two chains from the box are bigger looking than the original Oregon chain.
In the 4 chain pic, top is still brand new, 2nd is Oregon, 3rd is the other one from the 2-pck, the bottom is off my Stihl 18" MS261 18"and it is longer/bigger...
Hmmm... I'm still confused.
David
The second chain is some sort of safety chain.
note ramp
You should be able to pull the chain down slightly when it's "tight", and always tighten while lifting up on the end of the bar.
/edit and you are probably running the wrong chain for the sprocket.
It wouldn't be the first time a retailer put a saw together wrong.
   / Echo 18" CS420 - Chain keeps popping off and getting burred up... #23
Yes small branches, one smaller than a finger, but revving good, and not green, cut down by loggers in June...
Thanks,
David
I've seen small stuff like that throw more chains than anything else, not exactly sure why but that's what I've run into.
   / Echo 18" CS420 - Chain keeps popping off and getting burred up... #24
Lay the bar on a flat surface and make sure it has no warpage, that the bar groove is open all the way around with no pinching anywhere along it's entire length and once you've verified that install the correct chain, tighten it enough to allow you to move the chain, with gloves on, to verify it does not bind anywhere along the bar. Run the chain from the master link, (where two teeth are on the same side of the chain in sequence), all the way around the bar to where you began- again with no binding or tight spots. You should be able to pull the chain down maybe a half inch near the bottom of the bar close to the entry of the chain into the sprocket cover area, when the saw is cold.
   / Echo 18" CS420 - Chain keeps popping off and getting burred up... #25
Ya might as well take a good look at your star drive while you are at it. Whether or not you have a plain star or rim and sprocket system, something there might be buggered up by now.
When looking at a bar, I take it off the saw, clean the rails out with a putty knife or something of that nature. Pull the knife from the tip to the mount end. Clean it out good. Make sure your nose sprocket is free wheeling and not tweeked.
Take you bar with the cleaned rails and look down it to see if it is pinched any place or too fat. If you see overlap on your rails similar to what could be compared to musrooming on something else, file your rails by hand to knock those burrs off. Some guys will use a combo woodworking sanding disk/belt to dress their bars. Bars often need to be profiled or thrown away. A bar's profile is really important and if in doubt ask a professional in your area to show you one that is good, kinda worn, and flat worn out and you will have something to go from.
   / Echo 18" CS420 - Chain keeps popping off and getting burred up... #26
Has the drive sprocket, bar and chain been checked for compatibility?
Bump...
OK, I put the Echo away for a while because I got so mad when I went to pick up the sharpened and deburred chains the Oregon chain that it came with brand new had broke off a tooth and it was now scrap metal. So I grabbed the Stihl MS261 to see if it was me. Nope.
I cut for multiple weekends. I filled a buddy's 5x7 trailer twice, and the back of trusty rusty my 88 Ranger pickup at least 3 times and I've not even changed the chain yet.
I will go out and try the Echo again soon, when I have goof off time to figure out WTH is going on with it and try all the excellent advice given thus far.
Be well all,
David
   / Echo 18" CS420 - Chain keeps popping off and getting burred up... #28
Which is why, branches under 1" diameter, I never use a chainsaw on. I just carry my Silky folding saw along or attached to my belt and cut them with that. Only takes one stroke, maybe 2 on a dead dry oak branch. www.baileysonline has all sorts of trim saws and the full line of Silky's. The Silky folds up like a jacknife so the blade is inside the handle when not in use.... good investment for small branches IMO.
   / Echo 18" CS420 - Chain keeps popping off and getting burred up... #29
Well I'M confused reading this..
Is this a saw Echo CS400 or 420 like the title says
I have had 2 Echo chainsaws for many many years a CS 280 and a CS 4600
I always get my saw chains and bars from Bailey's also
   / Echo 18" CS420 - Chain keeps popping off and getting burred up... #30
Just bought an Echo 14" mainly for clearing privet and small trees from property line. I have experienced the same thing. Threw chain 3 times the first day, mostly on 3-4" thick stuff and almost always right at the end of the cut. Never had this problem on my 20" Poulan or 16" McCoullough or certainly never more than once in a day.
I think this thing throttles down more quickly than what I'm used to and so when finishing a cut, I might have let off too soon and the last splinters grabbed the chain and one time specifically I noticed that the last 1/4" got between bar and chain and slipped it over the end.
The very first thing I noticed right out of the box is how tight the chain was put on. So when switching and putting back on, I've been tightening it up good too. More than I usually do on previous saws.
2nd day using it, I threw chain 2 times. 3rd day once. I'm getting the hang of it.
Even as frustrating as this has been, I must say, this thing runs like a champ. Starts great, runs great, very easy to use. Might be the best saw I've owned if I can ever master throttling all the through the cut and making sure cutting away from the pressure points more than I ever have done.
2021 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A55852)
2021 Chevrolet...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
2022 John Deere 9RX 640 Track Tractor (A53485)
2022 John Deere...
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
2015 Chevrolet Silverado 3500HD 4x4 Crew Cab Service Truck (A53422)
2015 Chevrolet...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
