BT600 Boom Pin Removal
   / BT600 Boom Pin Removal #1
ehenry
Canton, ms
Kubota BX22 that was left to me by a dear friend. B7300 w/MMM
Has anyone removed the main pin pivot pin at the bottom of the boom? One of the dipper stick cylinder hoses has developed a leak. At least I hope its a hose....I was wondering if there are any words of wisdom or gotcha's that anyone that has done this before may have.
If its a hose I plan on replacing both while I have the pin out.
   / BT600 Boom Pin Removal #2
Good luck is all that I can say. I had a leaking hose in one of the backhoe cylinders, and could not get the boom pin out at all. I ended up having to take it to the dealer to have the pin removed and replaced every hose on the back hoe. Since the majority of the labor was just getting it apart, it was good insurance to replace them all.
I know that the boom pin on this machine has been removed twice before to replace hoses. I just wasn't the one that did it. I came up after the fact both times it was out and never saw him go back together with it
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
2024 CATERPILLAR 255 SKID STEER (A60429)
2024 CATERPILLAR...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
2014 Ford Transit Connect XLT Passenger Van (A59230)
2014 Ford Transit...
