Pole Carriage Shed
/ Pole Carriage Shed #1
Glassback
Vermont
Kubota L3301
I did a posting in January about a pole shop and shed I built last summer. I used logs from the property, with the help of my tractor of course. I'm taking on a bigger project building a 24x36 carriage shed using the same construction.
Here's the plan:
attachment.php
Here's what I've done so far:
attachment.php
The tractor has been key in getting the big logs into place. I can't say enough how much I appreciate my pallet forks but they wouldn't reach to the top of the ridge to place the beam. Here's where I'll probably get in trouble with the safety police but I got creative and made a boom to put up the beams.
attachment.php
attachment.php
It does look pretty hokey from the picts but it worked great. The yellow rope made it so I was able to position the beam from the seat of the tractor.
Here's my first pole building in case you're interested:
http://www.tractorbynet.com/forums/projects/329475-pole-shop-shed-building.html
/ Pole Carriage Shed #2
Looks pretty sweet. More challenging working with tapered logs.
/ Pole Carriage Shed #3
Nice. I really enjoy seeing things built from raw logs. It makes it more rustic and interesting!!!
/ Pole Carriage Shed #4
You gotta do what you have to do to get the job done.
Working with the tapered logs is pretty easy. For the horizontals I level the taper and measure from the underside to the sill and cut the posts. I plumb bob the verticals along their centers. I put strapping on the posts for the siding. I only have to chainsaw or hatchet the 3" spot where the strapping attaches to make sure the strapping is in the same vertical plane. Pretty easy once you start thinking that way.
Got the back rafters on. Hope to order the metal roofing next week.
attachment.php
Finished up the shed with siding milled from the property with the portable mill. Did metal roofing and put in lights and outlets. All set!
/ Pole Carriage Shed #8
Looks right out of 1870, except for the contents.
Bruce
/ Pole Carriage Shed #9
I am concerned about insects ravaging your posts, as they are not debarked...:2cents:
Nice concept, great work and awsome rustic looks!!:thumbsup:
You have fully utilized what nature had to offer you, and I quite respect this!:drink:
Well done.
/ Pole Carriage Shed #10
Awesome project and definitely strong enough to handle some Vermont snowfall!
Thanks for sharing
/ Pole Carriage Shed #11
Very nicely done. Love how natural it looks!!! Will this be your last building or do you have plans for other structures using similar materials?
/ Pole Carriage Shed #12
I really like the way that turned out.
What species logs?
/ Pole Carriage Shed #13
Finished up the shed with siding milled from the property with the portable mill. Did metal roofing and put in lights and outlets. All set! <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=452438"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=452439"/>
really nice job
/ Pole Carriage Shed #18
I hope to use simular methods to construct a new horse barn in the near future. We are blessed with plenty of locust trees, which tend to both grow straight, and resist rot well. Plan to start harvesting trees for the project when the weather breaks.
/ Pole Carriage Shed #20
Very nice.
It appears you have some logs in the ground. What were your thoughts about the risk of them rotting?
4 Bottom Plow (A65640)
Landoll 18' Tilloll (A66285)
Landoll 18'...
2018 Infiniti QX60 SUV (A64557)
2018 Infiniti QX60...
Mini Excavator Ripper Tooth (A66285)
Mini Excavator...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
