Weekend on the Ck2510
/ Weekend on the Ck2510 #1
southernAL
Gold Member
Dothan, AL
Kioti CK2510hst
Spent pretty much all weekend on the tractor. Had lots of fun, i'm thoroughly enjoying it!
Not sure why that last pic is upside down. But I got some good use out of my new Ken's bolt on hooks. Good product!
/ Weekend on the Ck2510 #6
Looking good. Is that a 5' brush hog? Have you tried it out yet? Or using it as ballast
/ Weekend on the Ck2510 #7
Looks good. It's easy to keep looking for things to do while tractoring. I've been very impressed with my 2510. I had kens hooks on mine for the first year and loved them. But I had to take them off.
/ Weekend on the Ck2510 #8
NIce grapple. I also like the expanded steel added to the front guard. A mod I'm planning to do.
/ Weekend on the Ck2510 #9
That's actually the platform from one of my old treestands. It fit perfectly inside the stock brush guard. The grapple is from Michigan iron and equipment and I like it a lot. I put about 5hrs into it today moving fire wood.
The rotary cutter is a 4' and I used it once so far. PSE, you have any other pics of that grapple? Is it bucket mounted? What do you use to control it? Looks good!
/ Weekend on the Ck2510 #11
Yes it's bucket mounted, there are 3 bolts through the bucket on each side holding the main bar on. The grapple can be removed from the mounted bar with 3 bolts/pins and the hydraulic connectors. I control it with a diverter kit so when I press the trigger on the new joy stick it changes the curl function to grapple function. I also built a tooth bar for the bucket.
/ Weekend on the Ck2510 #12
Nice work! Any more info on the tooth bar? Those are some serious looking teeth on it.
Thanks,
E.
/ Weekend on the Ck2510 #13
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
10ft Cattle Panels (A64047)
10ft Cattle Panels...
2014 FREIGHTLINER CASCADIA (A63569)
2014 FREIGHTLINER...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
2005 JLG 2646E2 26ft Electric Scissor Lift (A61572)
2005 JLG 2646E2...
2005 Deere 317 Rubber Tire Skid Steer (A64047)
2005 Deere 317...
