jeff9366
Super Star Member
- Joined
- Jan 14, 2011
- Messages
- 12,787
- Tractor
- Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
An MX size might be perfect and where you end up but I completely understand not being able to justify that expense to yourself and you family.
I'd sure like to see a video of you sitting on the hood blowing snow. No kink in the neck AND keeps your hind end warm. Sounds like a win win.I agree that HST is easiest for new operators. However, there are some advantages to a hydraulic reverser (gasp). They are mostly related to control position. One advantage is you can stand and operate forward, neutral and reverse with both feet firmly on the deck for better FEL visibility (my tractor never had one of those seat switches so many talk about). Second, for 3pt implements you can sit completely side saddle because your feet don't need to be near any controls. For snow blowing in revers, I can sit on the hood or stand facing backwards. HST has several advantages too but I'll let the HST fans handle those as I would not do them justice.
I am curious if the reason most have 3-point, PTO powered, snow blowers over FEL mounted, hydraulic powered blowers is cost?
Cost for a fel mounted blower is double the cost of a rear blower.
Tractors lack the hydraulic flow for doing such. The tractor in question had 16.8 GPM with 4 GPM devoted to power steering. That isn't nearly enough for a snow blower.We don't have much snow here in S. Central Texas and although I grew up in the mid-west we didn't have tractor mounted snow blowers. We did have pickup mounted front blades and I personally had an International Scout with a snow blade for our winters. We did have walk behind snow blowers. I am curious if the reason most have 3-point, PTO powered, snow blowers over FEL mounted, hydraulic powered blowers is cost? It seems to me that always backing up would be a big PIA? Sent from my iPad using TractorByNet
That would be a pretty big stump bucket, and a huge SS to match it. A SS big enough to run that would be in the 12,000-15,000 pound range. Let's get a 6 ton SS and 6 ton excavator and see which one digs a bigger hole.
And how is this helping the OP? Let's get back to options that help him dig his shallow rocks economically.
How many pages does it take to help the OP? Only so much can be said without beating a dead horse. While we are off topic, are you saying a 6 ton excavator isn't economical for digging a few small rocks? You know how pesky those things can be. That little rock sticking up to bang your mower blades sometimes turns out to be a 5 ton bolder.
The OP may be in an area of glacial till with very few large "bolders".That little rock sticking up to bang your mower blades sometimes turns out to be a 5 ton bolder.
Pretty soon we will all have FEL cameras.And that's one of the problems with short implements on the FEL of a conventional tractor.... you can't see where to place them sometimes because you're view is blocked by the hood of the tractor.
I almost give up, this far in a thread I'm almost surprised no one has mentioned what he really needs is a D6 cat and a M105.
As we reach consensus with more info from the OP we can discuss implements and brands. As far as The OP may be in an area of glacial till with very few large "bolders".
Has anyone modified a standard root type gravel so it had spacing more like a rock bucket ?
Pretty soon we will all have FEL cameras.![]()
