British Flat Face to NPTF
/ British Flat Face to NPTF #1
94BULLITT
Super Member
USA
yes
I am looking for a couple of adapter fittings. I need one that is male #8 British flat face to 3/4 male NPT and another one that is female #8 British flat face to 3/4 male NPT. Anybody know where I can find them? Thanks for any help.
/ British Flat Face to NPTF #2
I was in the mechanical trades most of my working career, and I had no idea what (male) NPTF is. Had to look it up. National Pipe Tapered Fuel. And I thought I was the master of esoterica.
I bow down to the new master.
Wouldn't NPT work? Sounds like NPTF is a PITA, same problems as screwed stainless steel pipe threads.
https://en.wikipedia.org/wiki/National_pipe_thread
/ British Flat Face to NPTF #3
You'll have to know if your British threads are tapered or parallel. It's obvious if you look closely. You might try Malone Specialty. On their site go to products/industrial/then online catalog. Its worth a try.
They also have thread identifying help.
Industrial and Transportation Products | Malone Specialty Inc.
I meant NPT.
I was looking at their site earlier and did not see anything. I may give them a call.
/ British Flat Face to NPTF #5
Maybe someone in the know can steer you in the right direction. I'm glad the ones on my IH backhoe and New Holland Skid steer are something more common. My brother has a Russian Belarus and it has British Standard Parallel Pipe threads BSPP, on it for the Aux Hydraulics. He adapted it to something else so he could find fittings easier.
/ British Flat Face to NPTF #6
Never heard of British flat face. Is that the same as British Standard Parallel Pipe threads BSPP?
I change my IH over from BSPT to JIC 15 years ago. Was not that hard to find them in Dallas. About 20% of the hydraulic shops had a good assortment of adaptors. I can't recall who I used.
/ British Flat Face to NPTF #8
Flat Face Fittings
The BSP and SAE Standard Flat face fittings have an O-ring groove in the male end. The thread form is shown in Chart #2 & Chart #7. The BSP version is used on Hiab cranes and loaders.
I got this from the Malone site I referenced above and thats the only mention of any flat face fittings that I have heard of.:confused3: When you go to the chart only BSPP and BSPT are shown just like everyone has mentioned. I have no clue, of course I'm no hydraulic man. Sorry no help.
I also have not heard of British flat face but the British taper and parallel fitting can be found at British Standard Pipe Tapered ( BSPT ) -- Tapered British Pipe thread fittings and Bspp fittings, British standard pipe respectively.
Are British flat face like our ORFS fittings? Flat with an O-ring in the face of the fitting?
Yes, they look like just like ORFS fittings.
I found a female British flat face to male NPT fitting made by gates. I might try to call Malone later, I wonder if they are open.
/ British Flat Face to NPTF #10
O-ring fitting are some of the best.
Why would you want a pipe fitting?
I need to adapt it to a filter base with pipe fittings.
2022 Takeuchi TL12R2 (A60462)
2022 Takeuchi...
2019 Nissan Sentra (A61574)
2019 Nissan Sentra...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64276)
KNOW BEFORE YOU...
(4) ASSORTED TIRES (A62613)
(4) ASSORTED TIRES...
2012 Chevrolet Sonic Hatchback (A61574)
2012 Chevrolet...
2007 Ford Crown Victoria Sedan (A61574)
2007 Ford Crown...
