tractor works
/ tractor works #1
banderson0655
selma,al
none
new to this am a experianced farm tractor mechanic with 25 yrs also work on heavy machinery and lift trucks
/ tractor works #2
Welcome! You'll fit in just fine.
What brands are you most familiar with?
/ tractor works #4
:welcome:
From Texas
/ tractor works #6
Welcome! You will add to the pool of knowledge!
/ tractor works #7
Welcome to the forum. :welcome:
We're happy to have you here!
/ tractor works #8
Welcome. Are sure you don't want to have this post deleted, (tractor mechanic) or turn tail and run, you have any idea how many question you could get, oh you do and glad to answer them, awesome.
I'll start, I saw this thread, (tractor works) I don't feel like doing alot of searching, my son says all diesel motors have to have a blower to suck in air so it will run, I don't see a blower on my L3400 tractor, all I see is what looks like an air intake manifold and an exhaust manifold, anyone else can answer if they dare
/ tractor works #9
Your son was talking about real tractors:D
/ tractor works #10
I am assuming we are talking about a turbo. Most small diesels are naturally aspirated and don't have turbos.
/ tractor works #11
Turbo, maybe that's what my son said, >aspirated<, he diffidently said that, he say's diesel's has to have something to blow air in the motor to run, but still I don't see no turbo on my L3400, so that must mean your right about naturally aspirated, which means a diesel motor sucks in air on the intake stroke.
My son is talking about changing his old straight six gas motor to a diesel motor, to run his shingle mill, if he can find one, the old 261 GMC is getting tired.
https://www.youtube.com/watch?v=gpd3ZOoI7kk
/ tractor works #12
That brings up an interesting question, but do you dare to answer it, how much horse power does it take to qualify for a (real tractor)? :eek::D Me I wouldn't go by HP, I'd go by (how big the front tires are compared to the rear tire's) my L3400 front tires are way to small compared to the rear, I guess the word is (disproportionate), try to spell that word with out spell check.:D
/ tractor works #13
I think he's talking about a 2-stroke diesel.
From Wikipedia:
Intake begins when the piston is near the bottom dead center. Air is admitted to the cylinder through ports in the cylinder wall (there are no intake valves). All two-stroke Diesel engines require artificial aspiration to operate, and will either use a mechanically driven blower or a turbo-compressor to charge the cylinder with air. In the early phase of intake, the air charge is also used to force out any remaining combustion gases from the preceding power stroke, a process referred to as scavenging.
As the piston rises, the intake charge of air is compressed. Near top dead center, fuel is injected, resulting in combustion due to the charge's extremely high pressure and heat created by compression, which drives the piston downward. As the piston moves downward in the cylinder, it will reach a point where the exhaust port is opened to expel the high-pressure combustion gasses. However, most current two-stroke diesel engines use top-mounted poppet valves and uniflow scavenging. Continued downward movement of the piston will expose the air intake ports in the cylinder wall, and the cycle will start again.
A diesel with valves doesn't require a blower or turbo.
/ tractor works #14
I'll answer right now. A real tractor has a three point hitch, or historical equivalent, and does enough work to get done what you need to get done.
When I had 1.5 acres a BX25 was plenty of tractor, moving up to 6 with a crap ton of stumps and the wife wanting about 2 acres of garden it wasn't a "real" tractor anymore...still around though because the wife likes it:thumbsup:
/ tractor works #15
EMD 2-stroke diesels have exhaust valves in the head and uses a Rootes blower.
/ tractor works #16
The L3400 must be a real tractor, does what I need it to do, but sometimes not what I want it to do, it's almost like I could use a 50hp tractor at times, but seems so any tractor with a back-hoe would work good removing stumps.
/ tractor works #17
So my L3400 must be a 4 stroke diesel, and a 2 stroke has a blower and that's why that motor is loader.
/ tractor works #18
The tipping point for me to get a bigger tractor was stumps. BX would pull four stumps in three hours. MX is averaging seven an hour. Guess it partially depends on how much time you have to dedicate to what you need to get done. Man, real tractors are too much like calculus:shocked:
/ tractor works #19
For me time and $$$$$$$$$$$$ is at a constant disagreement. I gave the MX series an online glance , looks like you picked the right size tractor for doing a lot of stumping and having a couple size tractor's to pick from for doing a job must make thing's nicer.
Case Titan 3530 (A61307)
Case Titan 3530...
(11) HAND SANITIZER STATIONS (A60736)
(11) HAND...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
2018 John Deere 590M S4 (A60463)
2018 John Deere...
72" Grapple Attachment (A60462)
72" Grapple...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
