3-Point Hitch m7040 kubota
/ m7040 kubota #1
game warden
macclenny,florida
kubota m7040
I bought a used m7040 Kubota been using it to load hay and everything seems to work just fine. Now it's time to plant some rye grass. When I try to hook up my implements to the 3pt. hitch the lift will not raise high enough to hook up. 3pt. hitch seems to work just fine, when I lower it drops to the ground and when I raise it comes up just fine but not high enough. I have made all adjustments on side and top links and still does not come up high enough. Is there other adjustments somewhere that I can adjust so that 3pt. will come up high ? Had a Ford tractor before and never had this problem, please help running out of time.
/ m7040 kubota #2
There should be two holes in the lift arms, one will lift more and one has greater range.
/ m7040 kubota
I have made all adjustments to the lift arms and top link and still will not raise high to work implements. If I tried real hard might be able to hook up a set of disc, but will not be able to travel without disc dragging on the ground.
/ m7040 kubota #4
I agree the 3PH on a M7040 does not lift high enough for my tastes either. But there are some things you can do.
>There is a lift limiting linkage that can be adjusted so the 3PH will lift until the hydraulic pump goes into relief.
Here is a photo of it. It is at the top of the left side lift arm. Adjusting it shorter will allow more lift. If it is too short then the pump goes into relief with the 3PH all the way up and the FEL doesn't work correctly until the 3PH is lowered. The idea is to adjust it just so when the 3PH is all the way up the pump and FEL works correctly. I gained about 6" of lift after adjusting mine.
>Also, you can get a second adjustable 3PH vertical lift arm (w/turnbuckle) so both lift arms can be shortened to the minimum length.
I have a hydraulic "tilt" for the right lift arm and transferred the right adjustable to the left side. Now both sides can be adjusted. That also increased the ground clearance. But you'd get the same effect with two mechanical vertical lift arms. Although a bit expensive, it would save the exorbitant cost of a hydraulic "top and tilt". (Although I highly recommend the T&T. Then when traveling you can shorten the hydraulic top link from the seat and the rear gang of disc pans easily clears the ground...like by 3 feet, or so.)
>You can cut down the solid vertical lift arm so it matches the adjustable arm in its shortest configuration and then weld it back together. That is probably the least desirable since adjustments would be limited.
Just to double check. The lower horizontal lift arm should be set at the hole farthest from the tractor and the vertical lift arm pin should be set in the top hole to get maximum height. Sound like you have already tried this.
/ m7040 kubota
Thanks for the info., just bought another adjustable vertical lift arm (with turnbuckle) going make both as short as possible. When I get back to my tractor I will give the lift limiting linkage a try. Looked in owners manual and saw nothing about that, thanks again !!!!
/ m7040 kubota #6
I've got T&T on an M7040...but also R4 tires, which lowers everything just a bit. I've noticed the 3pt not raising as high as I would like, but adjusting which holes the side links go to on the arms has pretty well taken care of it. And simply shorting the top link helps a great deal. T&T spoils you.
Having said that...I am not familiar with that lift linkage. Adjusting it shorter? From the pic I don't see how that's accomplished. I suppose it's in the manual, but I've never noticed it nor do I have it at hand. How is the adjustment done?
/ m7040 kubota #7
loosen the jam nut on turnbuckle, start tractor, raise lift all the way up, I think you shorten it ( i lift doesn't raise lengthen it ) till the engine loads, then back off a hair, tighten jam nut back up. won't find this in manual
/ m7040 kubota #8
Thanks. I'll check that....perhaps on a warmer and drier day.
/ m7040 kubota #9
I have an M7040 with factory cab on r4 tires.
I also have the workshop manual which my dealer provided on a USB stick when I bought my tractor.
The linkage being referred to is called the position feedback rod and its function has to do with providing a signal to the draft control.
I am not happy with the lift height in spite of using the high lift hole of the lift arms.
However, I would be reluctant to start messing with the feedback rod.
If you will park your tractor on a hard level surface and measure the height above ground with the lift arms down and up, I will do the same and then you will have a comparison.
Suggest we agree to take the measurements to the center of the implement attachment hole at the end of the arm.
Dave M7040
/ m7040 kubota #10
Dave M7040
OK....I'll do that tomorrow and let you know. I'd like it a 'little' better but I'm not having issues like game warden who started this thread. Just seems it should be higher. I had another M7040 in Texas with R1 tires, and I didn't even once think about the height the 3pt came up....so I kind of dissed it off as being an R4 tire thing. But I'll measure and post back.
/ m7040 kubota #11
One thing that is not readily apparent unless you had a choice to make when buying a new tractor like I did is that the R4 tires are on 28" rims and the R1's are on 30" rims.
So this lowers the tractor further than just the height of the tire lugs.
Dave m7040
/ m7040 kubota #12
Dave M7040
Not to start an argument, but that particular rod in the photo has nothing to do with the draft control. Notice where it is connected on each end.
The draft control does have a rod but it is attached to the top link bracket. A completely different issue. Draft control is varied by which top link mounting hole is used and the lever next to the driver's seat. BTW, I also have the factory workshop manual.
The lift control rod from the photo is adjusted like a turnbuckle (as already described). One end is right hand thread and the other a left hand thread. When you get it where you want and the hydraulic pump doesn't go into relief just tighten down the jamb nuts.
And let me assure you again...it has nothing to do with the draft control.
/ m7040 kubota #14
Wow! Is the 3-point lift arm height that much different between R1 & R4 tires. I have a M6040, which is the same frame as the M7040. Its on OEM 16.9 x 28 R1 tires. My arms will lift at least 6" higher than any of my implements.
/ m7040 kubota #15
gwdixon is absolutely correct.
This will teach me to do posts late at night!
This section of the WSM seems to have a simple checking procedure to adjusting the rod in question which affects the lift height.
I think the comparison between identical tractors I suggested will tell a lot to the original poster.
Dave m7040
/ m7040 kubota #16
I was thinking the hole in draft link closest to tractor will raise 3 pt higher. I know hole farthest away from tractor will raise more #s on 3 pt with all other things equal. Also attaching center link on tractor in bottom hole in bracket on tractor will raise rear of attached implements higher.
/ m7040 kubota #17
One way to evaluate a situation is to imagine the extreme case.
If the vertical lift arms were attached all the out to where the attachment balls are located then the vertical lift arms would be at a severe angle. This severe angle would shorten the the distance from the top of the vertical lift arm to the horizontal lift arm. In the extreme the vertical lift arm would approach being parallel with the horizontal lift arm. The horizontal lift arm would almost touch the place where the top of the vertical lift arm is attached thus raising the end ball higher so tall attachments could be hooked up.
See the crude drawing below. (I think we are talking about the same thing.)
Of course, theory is fine but to find out for sure requires an experiment!
/ m7040 kubota
First I want to thank everyone for all the info.. I also have the R4 tires and I know that will lower my height but you should still be able to use implements. When I lower my 3pt. hitch it will go to the ground and when I raise my 3pt. hitch it will raise 20 inches to the center of hole, not quite high enough to hook my disc up. I made all adjustments with top and side links. This is not my first tractor, but my first Kubota. Been raining last couple of days when it stops I will try all the info. I have got from everyone, again "THANKS" to everyone
/ m7040 kubota #19
With R1, tires the hitch doesn't get to the ground when lowered so you are correct, the tires make a difference. It appears that, with the adjustable vertical bars adjusted short, the attachment points should rise.
Hope some (or any) of the ideas work out for your situation. If not, post back and maybe a new responder will have the ideal solution!! Never know.
Quite a bit of curiosity at this point.
/ m7040 kubota #20
Dave M7040
Did this, but now rereading, I did not take a measurement in the down position. I had a landscape rake on the 3pt and did not want to take it off.
When I first got this tractor, it was noticeable that I did not have the lift height that I wanted. I adjusted the side lifts to the farthest hole on the arms, and also put the hyd top link in the lowest hole on the tractor. I'm fairly satisfied with that, but still not like my other M7040 that had R1s. Assuming the difference is the tires.
My center pin height is 27".
Hensley 16in. Bucket with Teeth Excavator Attachment (A64194)
Hensley 16in...
UNUSED RAYTREE RMRB72-72" HYD POWER RAKE BUCKET (A65055)
UNUSED RAYTREE...
2015 International WorkStar 7500 T/A Forestry Grapple Truck (A64556)
2015 International...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
(2) 4 WAY WRENCHES (A64276)
(2) 4 WAY WRENCHES...
2023 John Deere 317G Compact Track Loader Skid Steer (A64553)
2023 John Deere...
