hitch question
/ hitch question #1
white cloud
Rural South Carolina
Kubota L2501
This is going to be a little windy but please bear with me. My wife and I bought a travel trailer a few years ago. Our truck at the the time was a V6 Tacoma. This was a great truck but it was clearly not up to pulling the trailer. The trailer has a GVW of 6000 LBS and a tongue weight of 482 LBS. The dealer installed a weight distribution hitch that seems to work very well. My wife told me to quit screwing around and get enough truck. So I sold the Tacoma and bought a RAM 3500 Cummins. It pulls the trailer just fine! I adjusted the WDH to work with the new truck. This set up is great.
We have decided to purchase some forest property here in S.C. To help us manage this land I am thinking we need a tractor. I am looking at a Kabota B2320 or a John Deere 3032. I will need a trailer to pull the tractor and implements. I looked at a 20' Diamond C 14TUT. This looks like a nice trailer for this task. Any comments about this trailer would be appreciated.
I am finally getting to the question. I am thinking that the trailer + tractor + implements + whatever else I need is to tow is going to weigh > 6000 LBS. Do I need the weigh distribution hitch for this? If not, why not?
Thanks for reading all of this.
/ hitch question #2
I have never used a wd hitch, as I have always had 3/4 ton or larger trucks and hauled 12000+ on pintle hitch no issues, but was usually a balanced load as to not over load truck. On your 3500 if it was me I wouldn't mess with wd on an equipment trailer but if it makes you feel safer go for it.
/ hitch question #3
I would at least think about a goose neck. You can put a goose neck where it would be very hard to put a bumper pull, and they pull so sweet. Ed
/ hitch question
The truck has the prep for a fifth wheel/goose neck. I have never used it but apparently all I need to do is lock the ball and safety chain hooks in and I am ready to go. I had wondered about a goose neck but thought it might be "over the top". Do you know of a high quality smaller goose neck?
Thanks to all for your replies.
/ hitch question #6
I agree the wd hitch is over kill for 6k. Really if the truck rides ok and the headlights aren't in the sky I wouldn't worry about it. Right now 20' might seem long but go measure the tractors geared up and I bet you would be surprised at how long everything is. I just moved my neighbors jd 750 with loader, box blade and rake and it took up every inch of 20' deck. I still had a bit of tail space to use and I didn't need to balance the load because I had a long enough trailer and a 3/4 ton truck pulling it.I'd say I was in the 7-8k range with the trailer and payload. Never weighed the tractor so I'm guessing.
/ hitch question #7
No need for a GN under 12K with that truck. For that matter no need for WD for that load either.
Chris
/ hitch question #8
Check out the legal aspect for the use of a eight distributing hitch.
Exactly
Chris
"need" and legal requirement are two different things.
OP - read the manual, for my truck w/ factory hitch it says rated to 12k w/ WD, 5k w/o.
But in true TBN form let's start solving the problems you are not looking at yet and help you spend more money.
How much land, for what purpose?
IF you are going to be moving timber the
is too small.
My first tractor was advertised on CL as a Kabota B7610 (in 2009). Which is basically the same size as the 2320.
450824d1450361402-hitch-question-tractor-015small-jpg
The Kubota B7610 is the size I needed for maintaining narrow trails. To make those trails I needed more lift capacity and got an M4700.
When I bought the B7610 it came with a 12K trailer, 16+2 feet w/ 78 inches between the fenders. When I bought the M4700 it was about 84 inches wide.
Luckily I was able to narrow the wheelbase.
450825d1450361512-hitch-question-20140427_103025-jpg
So since you have not bought the trailer or tractor yet GO BIGGER if you can park it. I can barely squeeze my Hudson trailer, 24' overall, into my 2 car suburban concrete driveway. Fit's fine in my workshops in Mississippi :)
A few feet more for the trailer should be your minimum unless you have parking problems. and a 30HP PTO plus tractor is minimal for a forestry operation.
$2 HP isn't bad either :)
450826d1450361828-hitch-question-img_20151207_150524186_hdr-jpg
more room in the bucket for saws.
/ hitch question #9
There is a huge difference between a 1995 cummins 3500 and a 2015 cummins 3500. So what year truck did you get?
As to the tractor/trailer issue, first, dont compare a B2320 to a JD3032. Two different sizes. Compare apples to apples. the larger deere with a loader and bushhog is going to be a tight squeeze on a 20' trailer with little room to adjust load. But in any case, the Deere + loaded tires + loader + implement is not likely going to exceed 4500# So add the weight of the trailer. May be a tad over 6k, but not much, and certainly not enough to warrant a WD hitch IMO.
Do you have any plans to tow anything larger? A 3500 diesel is a overkill to a 6-7k tow. Any 1/2 ton built within the last 10+ years can handle that.
/ hitch question
My RAM is a 2015 3500 with the Cummins engine. It has the crew cab and the eight foot bed. It is an automatic. I am sure there are stouter trucks out there but going from the Tacoma to this was amazing.
Our plan is to purchase about 30 acres initially. I would expect to wind up with about 100 acres eventually Most of the land would be planted in pines as you can make some money off them. We have a forester who will engage loggers to harvest the pines and replant when it is appropriate to do so. I may be confused but I do not anticipate moving a lot of logs and such. Just cleaning up and planting food plots for deer, turkey and such. There is logging activity on my hunting lease and they can really bugger up a road so I expect to be spreading gravel and leveling out ruts in the access roads on our property after the loggers finish. I am very open to suggestions about tractor sizing.
Thank you.
/ hitch question #11
Just look at the hitch itself. It has a rating on it. Class 4 is 1000/10,000. You aren't even close to that.
/ hitch question
I looked in the truck's online manual. There is no mention of WDH requirements. The hitch is Class 5. RAM says max tongue weight is 1700 LBS.
/ hitch question #13
Good, so that answers one of your original questions.
Now as far as:
<snip>
Thank you.
That reads a lot like my situation. I've about 73 acres around the house and about 250 acres spread out over 4 parcels in the county. On one of them the hunters have managed to make a fair logging road totally impassable with their ATV's, even to them. Ruts 6 feet deep and 6 feet wide at the top and shaped like a V. I'e got to cut different paths around in order to set up some food plots by water.
The last picture of my M4700 was when I was in the woods two weeks ago "blazing" a path. I had to haul out some small trees of about 6 inches DBH. I could have done it with my B7610 but I would have had to cut them up into short sections, versus dragging the whole tree with just a little delimbing.
And if you are going to use ground engaging equipment for food plots you'll want more HP than the B2320.
/ hitch question #14
Look at the hitch itself. By law it is required to have a V-5 label on it. It will tell you the capacity with and without a weight distribution setup. If you are under the limit, you don't need it. If your are over, you should consider using it as the loads on the hitch may cause a failure. You can google "V-5 Hitch Label" and check out multiple images of what the label looks like. You should also check out the towing section of the owners guide as it will also advise you on the use of any special hitches. The ratings are typically based on SAE standards, not just some abstract manufacturers thoughts.
/ hitch question #15
I have a 2014 F150 ecoboost that is rated at about 10k trailer haul. My daughter has a 2013 F150 dually with a diesel. She can haul a tractor of that size without a WDH. She does pull a gooseneck horse trailer but you don't need a gooseneck for hauling a compact tractor
/ hitch question #16
The B2320 sounds a bit small. Let's hear a little more about what you will do with the tractor.
/ hitch question #17
What wolfpack2 said. Should be a tag on the hitch. Here's an example taken from my hitch.
Curt Model 15323 Class V XD
Towing Capacity
Weight Carrying Capacity: 16000.0 lbs.
Tongue Weight: 2400.0 lbs.
Weight Distribution: 17000 lbs.
Weight Distribution Tongue Weight: 2400 lbs.
/ hitch question #18
I'm pretty sure that Diamond C has a goose neck option on any equipment trailer they sell. The seem to be good trailers but I don't own one.
You may want to consider as big a trailer as you think you will need in the future, now while you are at it.
/ hitch question #19
Regardless of the tractor you get, go with at least an 18' but preferably a 20 foot trailer. I wouldn't mess with the cost of a gooseneck for what you are planning to haul, a bumper pull will do all you need to do and do it without a WD hitch.
/ hitch question
What about the JD 3032? Here are the tasks I see the tractor handling:
I need to be able to maintain the road going into the property so basically grade and spread gravel.
Fix the logging access once logging is complete. This will only occur occasionally.
Maintain a 2 to 4 acre plot of sunflowers for dove hunting.
Maintain some food plots for deer. So plant alfalfa.
All inputs valued.
Thanks to all!
2016 P.J. Deck Over Trailer, VIN # 4P5F82028G1250354 (A65563)
2016 P.J. Deck...
2023 CATERPILLAR 262D3 SKID STEER (A65053)
2023 CATERPILLAR...
2011 Black Troxell T120 Vacuum/Water Hauler (A64194)
2011 Black Troxell...
Stout Utility Grapple XHD76 (A66285)
Stout Utility...
JOHN DEERE M15 - 15' BATWING ROTARY MOWER (A64277)
JOHN DEERE M15 -...
2011 Ram 2500 Longhorn Laramie 5.7 HEM (A62679)
2011 Ram 2500...
