What would you like to see the tractor manufacturers to make.
   / What would you like to see the tractor manufacturers to make. #31
I'd like to see a small crawler with steal tracks in the 30hp range. A "CUC"compact utility crawler. Small baler, small row crop harvesters, and a small 30hp combine. Or a range of those in a towed models, like manufactured in 1950's. HS
Ever hear of Struck Corporation? Magnatrac MH8000 - Struck - Power Solutions for Today
Magnatrac MH8000
   / What would you like to see the tractor manufacturers to make. #32
I'll take my Massey 1652 exactly as it is... But with:
The new Grammar seat on the new MF 17xx series,
A turbo, boosting that 3.0L to around 65 HP,
The Kubota HST+ trans,
The rear exterior "creep" buttons that JD just added,
A pop-up sunroof like on the TYM cab units,
Gearing to accommodate 12x16.5 front tires like on the LS (and Case-NH) units, instead of the 10x16.5 ...
The cruise function from the previous Kubota Lxx40 machines (The lever controls and adjusts speed),
The fold down visor from the Kioti cab units,
The strength and underbelly protection that my skid steer has,
Hydraulic controlled SSQA levers,
The rear 3pt lever at the back of the machine (for adjusting the lift arm height when standing at the rear) like on the Kioti DK and NX units,
..... I think that's what would make me happy :D
   / What would you like to see the tractor manufacturers to make. #33
Yes... I'd like one of those also!!
   / What would you like to see the tractor manufacturers to make. #34
   / What would you like to see the tractor manufacturers to make. #35
An articulated tractor with a proper front axel and the engine on the right side for ballast. With a 3 point hitch and subframe for a backhoe. While we're dreaming here I want something the side and price of a scout that can load 4,000 pounds. Ok that already exists it is called a forklift, but I want an off concrete version.
   / What would you like to see the tractor manufacturers to make. #36
   / What would you like to see the tractor manufacturers to make. #37
Self leveling loaders available for all tractor sizes right down to the smallest.
Why do you have to buy a 65 HP tractor to get a self leveling loader?
Ridiculous!
My 43 hp Deere 110 comes standard with a self leveling loader... sometimes I would like to disable it... all depends on what I am doing.
   / What would you like to see the tractor manufacturers to make. #38
I do wish the tires on sub compacts would be of more robust construction... a lot of us have had tire issues...
All and all... I think the BX series is pretty darn good and no regrets.
   / What would you like to see the tractor manufacturers to make. #40
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
60 GALLON METAL OIL DRUM (A52708)
60 GALLON METAL...
2001 GMC C7500 Tree Truck (A55272)
2001 GMC C7500...
2016 Ford F-150 Pickup Truck 4x4 (A56858)
2016 Ford F-150...
40' CONTAINER (A52706)
Portable Restroom (A54865)
Portable Restroom...
