Buying Advice undecided about an 8n or international
   / undecided about an 8n or international
I'm struggling with this issue. my mind says I need to get the 424 international for $1900 is on a 12 volt system. the case 430 is $1650 diesel on a 6 volt. the 424 is a little stronger. anything I need to know about with each? thanks guys
   / undecided about an 8n or international #32
I'll be the first to say I don't know squat about Case tractors. But I have NEVER seen a direct start diesel on a 6 volt system. Does it have 2 6 volt batteries wired in series?
I'm sorry no it is a 12 volt.
   / undecided about an 8n or international #34
Been there. PHD with an 8N (well mine was a 2N) is a PITA. Got it stuck too many times. Then you spend all your time and energy to extract it. It's a man killer. And as mentioned, too fast of ground speed for a rototiller.
Been there and done that with the old 8N. Lots of fun with a big pipe wrench and a long breaker bar unwinding that thing. :ashamed: Glad I have the 'bota to do that kind of stuff now. The N is a great grass cutter/food plot tractor.
   / undecided about an 8n or international #35
The diesel Case will save you lots of $ on fuel if you plan to use it for many hours a year- though it may be a pain to start in really cold weather. I have a Case 530 diesel backhoe.
   / undecided about an 8n or international #36
My first tractor was a Case SC, liked it a lot. Had two rear remotes that I used to run a logging winch and the Eagle Claw hitch. Definitely a great tractor for its time. Hope you are taking care of yours.
   / undecided about an 8n or international #37
Yes- it was my great grand father's tractor so it stays in the shed. I haven't started it for about 2 years but it was my main workhorse for cutting/raking/baling hay 10 years ago. I turn the engine once or twice a year to be sure it isn't freezing up. There are many times that I miss the tight turning radius of the narrow front end...
   / undecided about an 8n or international #38
Edited- duplicate post
   / undecided about an 8n or international #39
I would run it occasionally and give it a chance to warm up the crankcase fully. Tractors that sit die a slow death.
   / undecided about an 8n or international #40
2016 Chevrolet Cruze Limited Sedan (A56859)
2016 Chevrolet...
Chemical Containers Tank (A57148)
Chemical...
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
3PT DRAG HARROW (A52708)
3PT DRAG HARROW...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
New Holland WorkMaster 37 (A53317)
New Holland...
