Buying Advice undecided about an 8n or international
   / undecided about an 8n or international
I'm struggling with this issue. my mind says I need to get the 424 international for $1900 is on a 12 volt system. the case 430 is $1650 diesel on a 6 volt. the 424 is a little stronger. anything I need to know about with each? thanks guys
   / undecided about an 8n or international #32
I'll be the first to say I don't know squat about Case tractors. But I have NEVER seen a direct start diesel on a 6 volt system. Does it have 2 6 volt batteries wired in series?
I'm sorry no it is a 12 volt.
   / undecided about an 8n or international #34
Been there. PHD with an 8N (well mine was a 2N) is a PITA. Got it stuck too many times. Then you spend all your time and energy to extract it. It's a man killer. And as mentioned, too fast of ground speed for a rototiller.
Been there and done that with the old 8N. Lots of fun with a big pipe wrench and a long breaker bar unwinding that thing. :ashamed: Glad I have the 'bota to do that kind of stuff now. The N is a great grass cutter/food plot tractor.
   / undecided about an 8n or international #35
The diesel Case will save you lots of $ on fuel if you plan to use it for many hours a year- though it may be a pain to start in really cold weather. I have a Case 530 diesel backhoe.
   / undecided about an 8n or international #36
My first tractor was a Case SC, liked it a lot. Had two rear remotes that I used to run a logging winch and the Eagle Claw hitch. Definitely a great tractor for its time. Hope you are taking care of yours.
   / undecided about an 8n or international #37
Yes- it was my great grand father's tractor so it stays in the shed. I haven't started it for about 2 years but it was my main workhorse for cutting/raking/baling hay 10 years ago. I turn the engine once or twice a year to be sure it isn't freezing up. There are many times that I miss the tight turning radius of the narrow front end...
   / undecided about an 8n or international #38
Edited- duplicate post
   / undecided about an 8n or international #39
I would run it occasionally and give it a chance to warm up the crankcase fully. Tractors that sit die a slow death.
   / undecided about an 8n or international #40
2022 Diamond T 14' Dump Trailer, VIN: 5FWDS1423NR030358, Manual Roll Top Tarp, Tandem Axle, 7 Gage (A59076)
2022 Diamond T 14'...
John Deere 6130M (A57148)
John Deere 6130M...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
McFarlane 4030 Reel Disk (A59814)
McFarlane 4030...
1707 (A58375)
1707 (A58375)
