Cheap chainsaw sharpener Einhell BG-CS 85 E
/ Cheap chainsaw sharpener Einhell BG-CS 85 E #1
Metsaman
Gold Member
Europe / Finland
Massey Ferguson
This kind gadget I bought in this week, quite cheap to buy ( 32,90 USD ) and seems to do good job... least better to Me in hand file.. :ashamed:
/ Cheap chainsaw sharpener Einhell BG-CS 85 E #2
They work well, have an Oregon sharpner, easy to take to much.
Seems to be so, both tooths on chain are similar... hard to get that by hand especially if chain are damaged...
/ Cheap chainsaw sharpener Einhell BG-CS 85 E #4
Be careful -- the cheap ones usually have enough slop that they can easily ruin a chain! They are not repeatable, so you can't get the same sharpening from cutter to cutter.
/ Cheap chainsaw sharpener Einhell BG-CS 85 E #5
For an accurate and repeatable resharpening, a TimberLine is your best bet. I use mine in the field (with a bar vise) all the time.
Yes.. I notice that but it makes also sharpening work flexible, just take what needed... nothing more..
/ Cheap chainsaw sharpener Einhell BG-CS 85 E #7
I use one too. They're worth the money.
I just watch Youtube video on that tool... handy I have to say.. !! :thumbsup:
/ Cheap chainsaw sharpener Einhell BG-CS 85 E #9
They ship worldwide too. No reason not to have one even if you don't live in the USA. Mine really works well, you only remove as much tooth as necessary.
/ Cheap chainsaw sharpener Einhell BG-CS 85 E #10
That's true! A friend bought a cheap one from Princess Auto when it was on sale and one immediate improvement was made by replacing the loosey goosey pivot shaft with a bolt that was a very close fit. We also did a bit of grinding on one piece to give it a larger radius to allow the chain to pass over it more smoothly.
/ Cheap chainsaw sharpener Einhell BG-CS 85 E #11
I just may have an identical sharpener. Found it much cheaper and accurate to hand file and then take it to a shop to get it done properly. So much for the bargain?
/ Cheap chainsaw sharpener Einhell BG-CS 85 E #12
I sometimes refer to those items that need tweaking to make into an acceptable product as being in 'kit form". :D
/ Cheap chainsaw sharpener Einhell BG-CS 85 E #14
/ Cheap chainsaw sharpener Einhell BG-CS 85 E #15
My success with kits is rather poor. They may also be called expensive bargains!
Yet the urge keeps striking even though I know better.
Exception: had good luck with wine and beer making kits I think. At least refills were asked for.
/ Cheap chainsaw sharpener Einhell BG-CS 85 E #16
I think this is a demonstration of how much you can take off with out overheating the chain.
/ Cheap chainsaw sharpener Einhell BG-CS 85 E #17
Can't resist "going to see the varmint", eh? :D
/ Cheap chainsaw sharpener Einhell BG-CS 85 E #18
Very true Mace. Problem is I'm scared of caves, can't swim and too darned old to remember what the varmit is all about!
2019 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2019 INTERNATIONAL...
2015 Ford Transit 250 Cargo Van (A64556)
2015 Ford Transit...
2013 Nissan Versa Sedan (A64557)
2013 Nissan Versa...
Bobcat 84in. Loader Bucket Skid Steer Attachment (A64553)
Bobcat 84in...
2016 Ford F-550 Flatbed Truck (A64556)
2016 Ford F-550...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 Brush Cutter (A64553)
2016 New Holland...
