Clutch pedal latch
/ Clutch pedal latch #1
txdon
Super Star Member
Central Texas
Kubota M6H-101
I noticed a clutch pedal latch to hold the clutch depresses on my L5030. I have not used it ever. Is it suppose to have a purpose?
/ Clutch pedal latch #2
I've never used one, but it is my understanding that it is to use for long term storage to keep the plates from sticking.
/ Clutch pedal latch #3
Yes. This is what the owner's manual for my B2320 has to say about storing the tractor for an extended period of time.
"Keep the clutch disengaged. If the clutch is left engaged for a long period of time, the clutch plate may rust, making clutch disengagement impossible at the next operation."
The manual doesn't define "extended" or "long," but six months would qualify IMO.
Steve
That makes sense, My Farmall clutch got stuck after not using it and a suggestion was to block it depressed. That fixed the problem. That was a 1947 tractor - the same problem occurs in the new tractors, now at least they have a latch instead of including a block of wood.
/ Clutch pedal latch #5
My B2320 came with a block of wood for that purpose.:)
Steve
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
UNUSED WOLVERINE HYD BRUSH CUTTER (A64281)
UNUSED WOLVERINE...
2007 FREIGHTLINER M2 106 4X2 26FT BOX TRUCK (A59912)
2007 FREIGHTLINER...
2005 JLG 2646E2 26ft Electric Scissor Lift (A61572)
2005 JLG 2646E2...
1993 International 4700 Crew Cab Landscape Dump Truck (A61573)
1993 International...
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
