Additive Measuring user friendly way
   / Additive Measuring user friendly way #1
kvcando13
NY
Eicher 2230
HI,
I am looking for Fuel Additive Measuring Device which should be user friendly.
My purpose is to mix 1 ml of additive oil to 5 Liters of Gasoline / Diesel.
Please suggest....
   / Additive Measuring user friendly way #2
G'day Mate and welcome to TBN from Downunder.
Perhaps I'm not reading your post correctly but; using a measuring cup (pour in 1ml) then pour it into a 5ltr container/jerrycan of petrol/diesel.
If the metric containers are not readily available in NY, nip across the boarder to Canada and purchase there. (Princess Auto & Canadian Tire, come to mind)
   / Additive Measuring user friendly way #4
Stop in your local veterinary clinic and pick up large syringe body. I have used them for years for precise small measurements.
   / Additive Measuring user friendly way #5
I have a measuring cup - calibrated in ounces & milliliters. Use it to add Power Service - Cetane Boost to my 5 gallon jerry cans of diesel fuel.
   / Additive Measuring user friendly way #6
Search for "lab measuring glass" or plastic. Tall and skinny containers make it very easy to accurately measure small quantities.
I use one that is about an inch in diameter and 7 or 8 inches tall and has a wide base.
   / Additive Measuring user friendly way #7
Use a marked syringe as Bud says. I don't care how good you are, you're not going to measure out 1ml with a measuring cup. :rolleyes:
   / Additive Measuring user friendly way #9
I just open the jug and pour some in, no measuring. A few oz. I don't think it matters that much... Some times I treat 6 gallon can, sometimes I just put some in tractor or RTV directly. HS
   / Additive Measuring user friendly way #10
When I comes to fuel additive, a little more is not detrimental.
Use some sort of simple small known sized container and eyeball it from there.
Some ideas:
Baby food container
Hair dye bottle
Spice containers
Dollar store measuring cup
Quick Attach Pallet Forks (A47384)
Quick Attach...
2014 Freightliner M2 106 Ambulance (A50323)
2014 Freightliner...
2022 CATERPILLAR D4 LGP CRAWLER DOZER (A51242)
2022 CATERPILLAR...
New JCT 7' Double Skidloader Grapple Bucket (A50774)
New JCT 7' Double...
48ft Low Boy T/A Trailer (A49346)
48ft Low Boy T/A...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
