Third time a charm?
/ Third time a charm? #1
Mowbizz
Lakes Region, NH
'14 Kubota BX25D
So...my BX25D has had the second block heater fail. Went out one frosty morning to heat her up and move some firewood.
Plugged the ext cord into the pigtail on the BX then went into the garage to plug it into the outlet...pop! I hear the circuit breaker go on the other side of garage. Hmmm...try again, same result. Got another cord...same thing. Went and got a short heavy cord from the house and same thing.
So...has my 2nd block heater failed after being replaced under warranty? Seems to be "shorted" or something. I took the extension cord and plugged in my air compressor and fired it up with no circuit breaker pop. Bad block heater...again. Called my dealer and explained the situation and he said wow, this is the 2nd one we have installed (after looking at the repair history). He said we'll be out on Monday to pick it up. What the heck could be going wrong with such a simple concept?
It worked fine all last winter after the 2nd one was installed...not a biggie, but I am quickly losing confidence in this particular accessory add-on.
I'll update when they tell me what was wrong with it...:mad: (that's if they even know themselves)
/ Third time a charm? #2
I had one fail after 6 hours of use. My dealers 200 miles away so I replaced it myself after he sent me a new one. Pretty disappointing to say the least.
/ Third time a charm? #3
I haven't used my block heater yet. At what temp do you start using it?
/ Third time a charm? #4
When ever a block heater that has not worked or failed every time I found all I had to do was replace the cord that came with it. A lot easier than replacing the block heater it's self.
/ Third time a charm? #6
The cord tested good. The heating element not so much.
/ Third time a charm? #9
They should change brands of block heater. If they are in an air pocket I could understand them failing.
/ Third time a charm? #10
I hope it's an easy place to get at for you some are a real bear. Ask the dealer if there's a certain way the element should be inside the block to allow for the most clearance.
I agree...seems to be something fishy with these. Maybe it's the "off season" that renders them useless somehow?
BX was picked up late yesterday and is now in the hands of the dealer. I hope there's a quick turnaround with a concrete explanation of why these block heaters are not cutting the mustard...
/ Third time a charm? #13
I installed mine myself, both times. I followed the instructions that were included in the kit when installing the one and ran the engine for a few hours. It was fine for the first two mornings, the third it was dead. One would think that the air would have worked its way out after working the tractor for a few hours.
On the second install, I followed the instructions, ran the engine for thirty minutes or so however this time without the radiator cap on. I replaced the radiator cap and put the tractor to work. The temp gauge went to operating temp and stayed there while working it. After I parked it, I loosened the radiator cap. It burped a bunch of air. With that, I'm not sure that the air purges like one expect. Just my 2 cents worth.
/ Third time a charm? #14
Hope so too (I don't have a high opinion of your likely dealer).
/ Third time a charm? #15
My block heater started leaking coolant out around the pins. My dealer had the replacement in stock, the parts guy said "they fail all the time, but most often its the cord and Kubota doesn't sell that by itself". Is that correct?
/ Third time a charm? #18
No comment. As you probably know, I mostly despise their sales department, not service.
No word from the dealer so far. They have had my BX since Monday and now it's Saturday. I called this morning and the service guy (who was supposedly, having "computer problems") could not give me any answers. I got the "I'll call you right back" and that was 2 hours ago...a little miffed at this point. all I want is my BX back with a working block heater.
/ Third time a charm? #20
Sucks. FYI, It's about 1.5hrs to Plainfield, NH! :stirthepot:
17601CFL (A61572)
17601CFL (A61572)
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
2018 Kenworth W900 Ext. Day Cab (A62613)
2018 Kenworth W900...
JOHN DEERE 5075E TRACTOR (A63291)
JOHN DEERE 5075E...
2022 EZ-GO ELITE...
Gleaner Variable Speed Header Drive (A63117)
Gleaner Variable...
