Glow plugs won't work TC33D
   / Glow plugs won't work TC33D #1
girls4
judsonia,ar.
4ooo ford ,new holland TC33d
Glow plugs won't come on when you turn to acc/run. Checked fuses and changed relays around since they are the same. Put new lamp timer on and checked all connections. Will light up for the 4 sec. when you turn to start. Other instrument lights come on put not glow plug in run so assume switch is good. Has one wire hot going to timer but none out. Wire diagram not actually same as book for some reason. Its a 2000 model I think. Starter doesn't kick in without crossing solenoid but know if problem is related. Worked at it long enough to consider you a genius if you can tell me the problem. Thanks.
   / Glow plugs won't work TC33D #2
When I had that problem it was the ignition switch. Replaced it and everything now works. They can lose contact inside the switch case. My tractor was much older, a 1970.
   / Glow plugs won't work TC33D #3
You said u swapped relays. I'm assuming R3 with R1. Do you have 12v on the brown wire of R3 when you turn the key.
   / Glow plugs won't work TC33D #4
Forgot about this. Was the ignition switch mod ever done to the tractor. There was an issue with too much current taking out the switch. Many of us purchased starter sol to bring in and fire the sol with the ign switch. Been a while, you'll have to search. But checking th brown wire I talk about will let you know if R3 is getting juice.
Another thing. Check the neutral safety switch. If u have a clip to clip laying around you can unplug the switch under the fender and jumper it to see if that's the issue.
   / Glow plugs won't work TC33D #5
Isn't the light run by the timer and gp s run by the ignition switch? There's a sticky on the switch on this forum - common fail point. Good luck.
Jim
Case Titan 3530 (A56435)
Case Titan 3530...
1992 CATERPILLAR 14G MOTORGRADER (A52709)
1992 CATERPILLAR...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56435)
2022 Brush Wolf...
1608 (A57192)
1608 (A57192)
2025 GPS Utility Trailer (A56859)
2025 GPS Utility...
