REAR TIRES WHEEPING METHONAL ACHOHOL
/ REAR TIRES WHEEPING METHONAL ACHOHOL #1
fraserfir
High View WV
B2650 kubota
Just wondering how to stop the weeping of alcohol from the rear wheel tires at the bead of tires? Tire and rims are new.
/ REAR TIRES WHEEPING METHONAL ACHOHOL #2
I would think that the typical rim seal compounds the shops use should do the trick.
Once caught with leaks on a cart that had small tubeless tires I got fed up adding air so I simply dabbed axle grease all around the rim edge and that cured my leaks. Might work on your rears as well. Downside is grease will attract dust and is messy.
/ REAR TIRES WHEEPING METHONAL ACHOHOL #3
So what is your tire pressure.?
/ REAR TIRES WHEEPING METHONAL ACHOHOL #4
Beet juice is heavier and thicker and therefor less likely to leak. Just a thought.
/ REAR TIRES WHEEPING METHONAL ACHOHOL #5
If you have low tire pressure since Beet juice is "slimy" it can make the bead slip. it acts as a lubricant. The wheel can actually turn within the tire.
/ REAR TIRES WHEEPING METHONAL ACHOHOL #6
Make sure the tire pressure is high enough.
/ REAR TIRES WHEEPING METHONAL ACHOHOL #7
Be glad it is not CaCl oozing out .
Pump the tires up to the max rated "bead seating pressure ". Then lower back down to 12psi or more if bias.
I don't hold air chucks on valve stems . A clip on air chuck with a valve and psi gauge may save a limb.
/ REAR TIRES WHEEPING METHONAL ACHOHOL #8
That was my first thought too. If is is then it will have to be pumped out and any anomalies with rim or tire will have to be discovered. Perhaps a piece of grit or something wrong with the rim, like perhaps it is badly bent? But low pressure seems the most likely based on his info. Did the leak just start ? Or was the fluid just added? Any more info would be helpful.
/ REAR TIRES WHEEPING METHONAL ACHOHOL #9
I would put tubes in if you pump the fluid out. If it's leaking around the bead I'm not sure what you can do other find out what the issue is (which will require the ballast to be removed and tire deflated). I doubt adding air is going to do much of anything but it's worth trying. If it's just one edge you might be able to lay the tire flat on the ground with the leaky bead facing up. It'll be heavy which means hard to deal with. But you could break the bead without loosing the fluid and make sure no dirt got into the bead. Then you could try some bead sealer once everything is cleaned up and dried off. But there's always the chance that, since tractor wheels don't have the lip like car wheels to hold the tire bead in place, the lower bead could come unseated and leak all your fluid onto the ground. But the weight of the fluid should put enough force onto the sidewall to keep it in place.
/ REAR TIRES WHEEPING METHONAL ACHOHOL #10
If tires and rims are new, then raising the air pressure to max per tire instructions should seat the tire bead to the rim. You could put some dish washing soap all around the tire bead/rim to make it slippery so it seats easier. Afterward just wash it off with a water hose, much less messy than grease and more slippery.
2019 John Deere 460E Articulated Dump Truck (A60352)
2019 John Deere...
2017 Loat 22ft Tilt Trailer (A59231)
2017 Loat 22ft...
Peterbilt 377 Semi-Truck (A61307)
Peterbilt 377...
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
2025 AGT Industrial MX-MRW14 (A60463)
2025 AGT...
2015 Ford Focus Sedan (A59231)
2015 Ford Focus...
