Kohler Generator use oil
   / Kohler Generator use oil #11
I had a Kohler command engine that was using lots of oil. The exhaust valve rocker arm nut was loose. Finally fell off and the engine quit running. That's how I found it.
Adjust the valves.......
I think it was Consumer Reports that had a write up about new cars burning oil... sometimes a quart or two between oil changes. IIRC it was possibly attributed to the use of low viscosity, usually synthetic, oil to help meet mileage standards. check, What type/viscosity of oil are you using in the generator?
I am using Syntec 5-30 synthetic.
   / Kohler Generator use oil #15
As an example, I have a Briggs & Stratton 20kW propane generator that ran 220 hours straight last winter in brutal cold. It used NO oil at all during that timeframe. I also have a Kohler 14kW propane generator just installed at my flip house next door. So I have no data on that particular gen set, but your's should not have sucked that much oil in that low use timeframe. Too bad you didn't have it taken care of while under warranty- BUT maybe if you plead your case to Kohler they can assist in getting it right for you now.
   / Kohler Generator use oil #16
Sometimes if the owner switches to synthetic oil too soon the rings never seat properly and you will get the oil consumption you are experiencing.
What oil are you using?
Dave M7040
   / Kohler Generator use oil #17
Dave M7040
That's just not the case anymore, if it ever was. Many, many manufacturers supply engines with synthetic oil from the factory; including my Briggs & Stratton 20kW genset from 2009. No oil issues at all.
   / Kohler Generator use oil #18
I have a whole house generic propane 17 kw air cooled engine.I also burn 5w-30 synthetic oil.My gen. ran 24-7 for about 4 days straight last year during a storm used no oil.I did have my valves adjusted at about 50-70 hours.As others have stated might be a good thing to do.
   / Kohler Generator use oil #19
Switch to straight 40wt viscosity oil. There are synthetic straight weight motorcyle oils on the market.
Thanks, coobie - I will check that out. Great suggestions, everyone!
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
2017 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2017 PETERBILT 579...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2016 FREIGHTLINER...
1262 (A50490)
1262 (A50490)
IH Farmall 504 Tractor (A50514)
IH Farmall 504...
1266 (A50490)
1266 (A50490)
