tman1020
- Joined
- Jan 16, 2014
- Messages
- 1,467
- Location
- north west indiana
- Tractor
- Bobcat ct225 and Bad Boy zero turn
For those of you that have steel sheeting on ceiling how much over lap if any did u use?
I'm talking about overlap of the ends not on the ribs. I've never used it for sheeting a ceiling before and I was wondering if I should just butt the ends together as you would wood sheeting or should I use some overlap?
How big is the building? I know you are looking for an economical solution, but a real ceiling under your trusses with blown in insulation is probably the best choice. A liner panel metal ceiling is less than $1 per square foot and then the insulation will be less than that.
30 x 40 seems huge for a workshop. Do you really use it all for workshop?
The cost is one of those one shot, swallow hard and do it kind of things. From my perspective, the time you save by not having to finish and paint the ceiling is worth a lot. And you probably won't have to paint it for the life of the building. The upside down install isn't really an issue. A drywall lift will handle the metal and weight is minimal, even with 16 foot pieces. I think the metal will go up in a fraction of time of other options.
Maybe Eddie could clarify, but I think they even have pointed screws that will penetrate liner panel and then screw itself into the wood very easily. I would not nail.
Kenny nailed it again!!! I bought my ceiling metal from and Amish shop near here. They call it liner panel. Has cheaper grade paint with no fading guarantee. Pretty hard to get fading inside a shop. As for hanging it, did mine myself with a $150 drywall lift. Cheapest hired hand I've ever had. My building is 42x50 and I think my metal was around $800. I'm sure it was less than $1000. I'll never touch my ceiling again. And as mentioned looks great. <img src="http://www.tractorbynet.com/forums/files/rural-living/448771-insulation-shop-ceiling-20150119_181652-1280x720-jpg"/>
Yeah, we're a classy clan.![]()
I'll have to put the lights and stuffed animal in my budget when I build my shop.Yours is pretty swanky by the way.
If you ask my wife she'll say I live out here. Do kinda wish I had put a shower in the bathroom....![]()
I'd live out there too....funny, my wife asked if I'm going to build in a place to sleep in the shop. Huh?
