Tractor Sizing Need help with tractor selection
/ Need help with tractor selection #1
Jjm1
Irwin, pa
John deere
Hi. As a new member, I was hoping I could get some opinions on tractor size. As background, I currently own a Cat 420D backhoe so don't need a loader or backhoe. I currently cut 5 acres of flat ground and looking to cut down on my mowing time. I've decided on buying an 84 inch mower (812 lbs) and wondering if a Kubota L3901 would be enough tractor. On paper it has enough PTO hp. I could step up to a Kubota L4701 but, worried the heavier weight may rut the yard too much. I plan on going with turf tires. I may also occasionally use the tractor with a brush hog or rototiller for food plots. Thanks for your thoughts.
/ Need help with tractor selection #2
I think you will be alright. I pull a mower that is 100 pounds lighter and 1 foot narrower with B7100. The B7100 is way too small, but it gets the grass mowed.
/ Need help with tractor selection #3
The 3901 should handle an 84" rear finish mower just fine.
I run an 84" rear discharge rear finish mower on my 34 HP (28.3 PTO HP) tractor with no problem.
Thank you
/ Need help with tractor selection #5
I suggest Turf tires and just a little front weight. (Foam the front tires?) I agree you should be good with the L3901 as an oversize lawn mower.
/ Need help with tractor selection #6
I was running a 90" RFM behind my Massey, and finally sold it because it wasn't really any faster than my ZTR. If you're really only cutting grass/light weeds on level ground, a commercial ZTR will cost a lot less, and be just as fast, if not faster.
/ Need help with tractor selection #7
Agree... I can cut 5 acres at my place in a little over 2 hours with my 66" Hustler Super Z diesel. My buddy used to cut his property with an 84" finish mower, but sold that and bought a Scag Cheetah 61" and cuts his property faster.
I'd opt for a zero turn all the way
/ Need help with tractor selection #8
Selection of tractor depends upon following factors:
1. Land holding
2. Type of crops
3. Soil condition
4. Type of Weather
5. Repairing facilities
6. Running cost
7. Initial cost
8. Resale cost
All these factors should be kept in mind before you buy a tractor, because buying a tractor is large investment. So it is best to go through a proper survey before you select any tractor for yourself.
:):thumbsup:
/ Need help with tractor selection #9
I mow around 7 acres of lawn.
My 35 HP tractor with 84" rear finish mower takes a little over 3 hours to mow.
I can mow it with our Hustler Super Z 72" zero turn mower in 2 hours.
/ Need help with tractor selection #10
Hard to beat a ztr for mowing. But it won't do the filling and bushhogging you want.
For mowing being a primary task but option to till and hog as a must, I'd be looking for the largest you can get with a mmm. Not up on current models, but something like a b3300 with mmm
/ Need help with tractor selection #11
There's such good info in here, I figured I'd bring it back from the dead instead of starting one in the newbie section.
In your guys' opinion, why is mowing w/ a ZTR the quickest? What about if you don't have much to maneuver around?
I ask because I don't have much tractor experience. I have two flat, treeless acres (pretty much the easiest mowing there is, although I have to maneuver around pool, trampoline, and swingset). I currently have a 60" (8 mph) ZTR that I upgraded to because my 50" riding mower was too slow. I need something that will also plow snow, so I was thinking of replacing the ZTR w/ a decent used 4x4 tractor that would have a front loader to plow, and I could tow behind a 72" finish mower. I was thinking some compact tractor (like a B7500) w/ about 25-30 HP. I keep my grass short, and mow every 7-10 days in the spring. I figured that the wider deck and higher mow speed would cancel out my lack of manueverability and the mow time would stay about the same.
How much PTO power do you need to pull a 72" finish mower? I know the manufacturer's list a range, but I'd like your guys' experience to see if the bottom of the range is ok, or should spend the extra bucks to stay near the top.
Thanks!
/ Need help with tractor selection #12
You won't get higher mow speed with a tractor. Every turn takes 2-3 times as long. I also have an 8 ft flail mower that I use with my 52 HP tractor. One of my pastures, which is about 3 acres, can function as a very nice lawn if I have time to keep up with it weekly on the ZTR. But if I let it go, then I have to tame it back down again with the flail for a few mows, before I can get back to the ZTR.
Even when it's kept at a typical "mowing height" I've compared speeds using my tractor with the 8' flail, 8' Brush-hog (twin blade pull type), and the 66" ZTR. It's still no comparison. The ZTR cuts faster, and leaves a nicer finish. In fairness, my ZTR cuts nicely at 11 mph.
I'm not sure what your snow plow needs would be, but what about getting a 4-wheeler with a plow?
/ Need help with tractor selection #13
Thanks!
I don't believe a 72" finish mower would be faster than a 60" ZTR. I compared times using a 90" finish mower to a 48" ZTR for about an acre (area around my house) and they were about the same, although there were trees and a fence line involved that slowed the tractor down.
The guy I sold the 90" finish mower to (Sitrex SM230, which has 5 blades) said he put it on a Ford 8N and it worked nicely...that's a max of about 23hp at the PTO for a newer model. I think 25hp at the PTO is fine for a 72" finish mower.
/ Need help with tractor selection #14
Thanks for your input. Honestly, (and I can see from your signature that you don't have this worry) I don't really want a bunch of pieces of machinery to have to maintain. Another oil change to do, more stuff to break, more space taken up in the garage. Although I suppose finish mowers have their own maintenance needs w/ greasing, gearbox oil, etc.
I was hoping the tractor could do both. Plus, by the time you pay for a decent ZTR and 4 wheeler/plow it's cost you as much. And, the tractor is more versatile than a 4 wheeler, there may be non-snow times I'd like to use the front loader or back hoe to plant trees, unload gravel/mulch out of the trailer, etc.
/ Need help with tractor selection #15
ZTR will still be faster, but in either case, its not like it takes a long time to mow 2 acres with either choice. what may take 30 minutes on the ZTR may take 40-45 on the B7500.
So 10-15 minute difference isnt that much. But if you were mowing 20 acres, that would be like 10 hours vs 15.
Top speed on the B is only like 9.5 MPH, and pulling a 6' mower, it is unlikely you will get a nice cut pulling top speed. You are probably looking at 7-8 MPH tops but depends on the mower and blade speed.
/ Need help with tractor selection #16
/ Need help with tractor selection #17
My ZTR will beat the B7100 bad in mowing time. I think my ZTR would be pretty close to my 72" finish mower in a large area with few obstacles. My F-series Kubota will hang right with the ZTR. If the grass was tall the F-series would beat the ZTR. Only mowing 2 acres it won't be a huge deal either way.
/ Need help with tractor selection #18
My zero turn will mow circles around my tractor.
Takes me around 3 1/4 hours to mow my 7 acre lawn with a 35 HP tractor w/84" rear finish mower.
I can mow the same lawn with my 35 HP w/72" deck zero turn in 2 hours. On the smoother parts of the lawn I can mow at full speed (13-14 MPH).
I've had this thing for 2 years now and it still impresses me how fast it can mow.
/ Need help with tractor selection #19
You must have a very smooth yard , 13 mph ?
/ Need help with tractor selection #20
Some parts of the yard are smooth enough, other parts of the yard you need to slow down.
Been mowing the yard long enough we know where the bumps are.
The zero turn has suspension seat, flex fork front suspension and 7-8 PSI tire pressure.
The ride is pretty good. Much smoother than my tractor at higher speeds.
2025 80in. Hydraulic Dual Cylinder Root Grapple Skid Steer Attachment (A61567)
2025 80in...
UNUSED KUBOTA M1875 FRT BUMPER (A62130)
UNUSED KUBOTA...
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
2021 CATERPILLAR 302.7DCR EXCAVATOR (A62129)
2021 CATERPILLAR...
2023 New Holland C327 Compact Track Loader Skid Steer (A61567)
2023 New Holland...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
