Double Post, Double Post....I'm seeing Double
/ Double Post, Double Post....I'm seeing Double #1
Kyle_in_Tex
Super Star Member
East Central, Texas
JD 4310,JD5420
So far this morning, 4 out of 5 postings have been doubled.
/ Double Post, Double Post....I'm seeing Double #2
I think it may have something to do with a delay and the posting doesn't seem to go through so we hit it again. I have done that in the past.
/ Double Post, Double Post....I'm seeing Double #3
I have done it a few times, and I know I only hit the button once, but there was some kind of weird delay
/ Double Post, Double Post....I'm seeing Double #4
I recheck after I post and if there is a duplicate, I delete the second one. Or sometimes the first one.
/ Double Post, Double Post....I'm seeing Double #5
Sounds like a good way to get double the activity on a website. Just sayin...
/ Double Post, Double Post....I'm seeing Double #6
If you use the new posts option, and use Firefox, I've found that using the pulldown menu and going back to the search results page instead of the back button alleviates the double post issue. Which only occurs when it hangs and the "leave page" dialog box appears.
/ Double Post, Double Post....I'm seeing Double #7
I use Firefox and am getting real,y frustrated with the double posts. I don't hit the save button more than once. It just hangs and double posts. I think the server is too slow and can't handle the volume.
I finally gave up deleting the doubled posts. If it wants to double post, so be it, I'm not deleting them anymore.
I've never heard a mod or administrator address the issue on this site either.
Too bad, because it's one of the nicest sites with the most useful info and nicest people I've come across.
/ Double Post, Double Post....I'm seeing Double #9
That is the way I do it. Just delete the second post. No big deal to me.
/ Double Post, Double Post....I'm seeing Double #10
Same here, just delete one and go on.... or don't delete one... it just doesn't matter in the big scheme of things.:confused3:
/ Double Post, Double Post....I'm seeing Double #11
My iPad flashes a warning that it is a double post. I cancel the post and then hit refresh page. Only one post shows up.
/ Double Post, Double Post....I'm seeing Double #12
I started being real careful that I'm not hitting enter twice. Most of my posts still post double.
Composed and posted at once, composed and edited through a couple of drafts before posting, abandoned draft restored from auto-saved and posted, makes no difference, near everything posts double.
/ Double Post, Double Post....I'm seeing Double #13
That post I just made appeared to post properly, it was the final post in the thread.
On a hunch I refreshed the screen and found the draft of it had appeared in the Quick Reply box below the post. Then deleting that draft made it disappear.
/ Double Post, Double Post....I'm seeing Double #14
Yep, no incentive to fix something that only helps TBN record extra posting activity. It might have been programmed in....
/ Double Post, Double Post....I'm seeing Double #15
Yep, trying to get to 5 million posts.
I always delete the last double.
/ Double Post, Double Post....I'm seeing Double #16
Hey California, sounds like you've got the magic touch! If I send you a $20 bill, can you double it for me? :laughing:
/ Double Post, Double Post....I'm seeing Double #17
I always suspected that Firefox doesn't play so nice with VBulletin or vice versa. (IE'x' works better than FF with many Java-based sites, btw, but MS and Oracle have been seen leaving a cheap motel ...)
Over at PM (also a VB site) double posts come in waves from time to time.
(Just working-up my post count. :D)
/ Double Post, Double Post....I'm seeing Double #18
I've never had a double-post myself, but I've seen countless numbers of them from others.
Now, within the last week, I am seeing situations where the duplicate post appears hours after the first; in one instance 10 hours between original post and it's duplicate. Most of them however appear to be the "conventional" immediate double-post.
There should be a contest - predict the time of the first Triple-Post.
PAIR OF PIPE RACKS (A68842)
PAIR OF PIPE RACKS...
1947 Chevrolet Panel (A62613)
1947 Chevrolet...
2000 FREIGHTLINER FLD120 (A67714)
2000 FREIGHTLINER...
2016 Ford Escape SUV (A66738)
2016 Ford Escape...
2014 MAC FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2014 MAC FLAMELESS...
2019 JOHN DEERE 750K LGP CRAWLER DOZER (A65056)
2019 JOHN DEERE...
