Oil & Fuel Adjust idle speed on Ford 3000 (has Simms fuel injection pump)
/ Adjust idle speed on Ford 3000 (has Simms fuel injection pump) #1
rmorgan3000
Black Mountain, NC
Ford 3000 diesel
How is the idle speed and maximum no load speed adjusted on a 1971 Ford model 3000 tractor adjusted? This has a Simms fuel injection pump that has been refurbished. Rmorgan
/ Adjust idle speed on Ford 3000 (has Simms fuel injection pump) #2
Go to the hew New Holland Forum and post this. There are a couple of knowledgeable folks there who may be ale to help you. Generally speaking, you put the throttle in the idle position and
use a screw to set the lo idle stop. I'm not sure but I think it's the same with the high idle.
/ Adjust idle speed on Ford 3000 (has Simms fuel injection pump) #3
BOX BLADE (A58214)
BOX BLADE (A58214)
Madvac CS500 Sweeper (A61166)
Madvac CS500...
2018 Dodge Grand Caravan SXT Van (A59231)
2018 Dodge Grand...
2007 Ford F-250 4x4 Crew Cab 7ft. Flatbed Truck (A59230)
2007 Ford F-250...
Deere 410L (A53317)
Deere 410L (A53317)
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
