3-Point Hitch Kubota B2620
/ Kubota B2620 #1
DianneInVA
Fosston, MN
Kubota L3301
I need to move the BH65. I know the "correct way" is to remove the 3pt hitch and install the Backhoe on the B2620. However, it is cold and I will need the hitch again before I need to use the BH. Is there a safe/practical way to lift and move the BH and with the FEL and chains? Just asking.
/ Kubota B2620 #2
It's barely possible. You have to use the curl function. Watch the chains don't bend or damage it.
It's been a few years but seems to me I used 2 chains or a chain and a strap.
/ Kubota B2620 #3
I wouldn't risk damaging the TPH or BH by trying to get the BH and the TPH on at the same time. It is easy enough to remove the BH and then install the the TPH.
/ Kubota B2620
Everyone - of course - was right. I typed that in a moment of weakness, In the end, I did the correct thing and it was probably the easiest BH install ever!
/ Kubota B2620
I thought about this, but in the end - removed the TPH and installed the BH. If felt so good and was the easiest ever- but would still like to see the guy who can do it in 15 minutes. BTW, in Michigan - you understand cold!
/ Kubota B2620 #6
Good deal. Yes we understand cold here
I had no real choice. I bought the backhoe used and had to get it on my trailer. My son and I used his loader to get it on the trailer. We rigged it carefully to avoid bending or breaking. It took a couple of tries to find a good way of attachment.
/ Kubota B2620
If I could have figured out a safe way...I slung chains around the cultivator and the rear blade, but that was easy (and they were cheap) The reason I am moving this stuff so late in the season, was the last minute addition of some cows. Didn't want them chewing on the hydraulic cables.
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61567)
2016 Ford F-150...
2014 Land Rover LR2 AWD SUV (A61574)
2014 Land Rover...
UNUSED ATSPOWER GASLESS WELDING MACHINE (A64281)
UNUSED ATSPOWER...
KUHN SR108 GII 8 WHEEL SPEEDRAKE (A63291)
KUHN SR108 GII 8...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
11120 (A64280)
11120 (A64280)
